TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,084
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
You know, I just don't know what to think anymore. To be honest SDT, what your saying sounds plausible and reasonable. The Mahindra guy I talked to didn't know what I meant when I asked if the Max 25 had position Control. Many have verified that the Mahindra does have PC, but there is some discussion if this is simply a matter of the clamps that help in setting the height at the same exact spot each time you cycle the 3pt, or if it's what you just said. I can tell you that after the posts above, I spoke with 4 dealers of different brands on a recent information gathering mission, and they all said that if a 3pt hitch is "Drifting" than there is something wrong with the 3pt hitch, and all of them should stay where you put them. But I am finding out that being a dealer is nota a qualifier for always giving out precise information. I don't know if these guys are just oversimplifying things for the customer, of if they genuinely don't know. I guess maybe a better question might be, how fast is the "Drift" on a non PC 3 point? In conversations with different dealers, they never mentioned a problem with having to constantly fiddle with the height on the tiller for instance. They did say however that you can adjust the depth the tiller cuts in with the 3pt, which logically leads one to believe that if drift is occurring, that it is not something that happens quickly. At least fast enough to where it would be a problem when tilling a small garden. If position control is as you describe it, and it may well be, I find myself wondering how important it is overall on a SCUT sized tractor anyhow. Besides the tiller, I can't think of any operations where Drift would be an issue anyhow.
Just as an FYI, the John Deere 1026R has position control.
I use a tiller as well as a rotary cutter on my BX2660 and every once in a while I will have to bump the rotary cutter back up as it won't maintain a constant height, it has become automatic just like bumping up the box scraper when using it as ballast.
Some owners will use chains to keep the rotary cutter at a constant height, I had an old thread on this saved on another computer. For many this is not a big deal as they continue to sell them this way.
