GC1705 - snow removal near Denver
   / GC1705 - snow removal near Denver #11
I find myself using my rear blade to remove snow instead of my front 4 in 1. It's easy to see what you are doing and adding a top and tilt kit makes the blade even more useful.
Curious - what did people spend on the blower or front blade kits, if you purchased them after the fact? Seems so spendy given I spent about $9k on the tractor with the FEL, mower deck, and a plow. Does anyone have a picture of how that 'subframe' attaches to the frame?
   / GC1705 - snow removal near Denver #13
For me, the best option, was none of the above.
A loader mounted plow is the way to go.
Economical, if you can fabricate. No snow blowing in your face. Way faster than using the bucket. Faster than a blower. No shear pins. Better than a frame mounted plow, because, you can push the tops off snow piles, if they get too high.
   / GC1705 - snow removal near Denver #14
I'm in the same boat. I got a 1710 in April but I also am getting a diesel pickup next week. Front blower is about the same as a big truck plow. Hmmmm
   / GC1705 - snow removal near Denver #15
I have a new GC1720 and will be in the same boat. My plan is to leave the bucket on and pick up a rear-mount snowblower. Blow the snow you can, bucket provides ballast; use the bucket to pick up and toss what cannot be blown, blower provides the ballast.
I agree with this viewpoint. I use a Kubota in eastern mountains whose snowfall is about what you describe. Big difference is yours is dry powder. A few points to consider:
-- I would not want to give up the FEL. Yes, it is a pain in the neck so to speak to have to turn around all the time and watch either a rear blower or the rear blade.
-- You can get a blade to fit on the bucket. It would have been better had you got a quick disconnect set of skid steer plates on your loader frame if that was available.
-- A large % of the time you can probably get by with just the loader bucket and maybe an attachment blade. With a bit more snow go to the rear blade. With a bigger storm bother to put on the blower.
-- Everything is compromise. A front blower is a much bigger job to put on and take off and more expensive for sure. Yes it is nicer for pure snow work BUT I find that a combo of front bucket and rear blower allows me to "work both directions" wasting less time and clearing things quicker. There will always be "chunks and lumps" you want the FEL to move as well as tight spots for which the blower is not the right tool. My thinking is the same as coldsteeva. And he is exactly right about ballast.
   / GC1705 - snow removal near Denver #16
I have a paved driveway, also facing north, about 200 feet OA, with a wider section in front of the garage. When I bought the tractor, I ordered a blower with it and never regretted it.
Initially my driveway was gravel (needed to pack down a good base first), but now that it's paved I have the blower feet all the way up-- they don't come into the picture at all. I'm able to scrape it right down to the pavement, and the first hint of sun clears & dries it off. It is rough on the scraper blade, but they're easy enough to flip to get some more use out of them and then replace when they're worn down too much. Pavement has a few scrapes here & there, but nothing I'm worried about. Not sure about concrete.
For those few times when I'd like to use the FEL, I can drop my blower onto a flat 4-wheeled dolly, raise the front blower mounting shoe (but leave it on) and mount the FEL, all in about 8 minutes or less. Dropping the FEL and re-mounting the blower takes a bit longer, but not much. The front-mount shoe etc. for the blower doesn't come off until spring when I service the blower one last time and then put it up.
If you have a place to put the snow, a blade is going to be the fastest and least expensive. If you don't, and don't want the inevitable ridges on the sides of your driveway from plowed snow, the blower's the better choice, IMO. I'll bet that if you had the blower you'd find that you really wouldn't need the FEL.
As far as those few light dustings of snow, heck yeah-- I've used my backpack leaf blower or even a 36" rubber-edged garage floor squeegee!
   / GC1705 - snow removal near Denver #17
Got an ATV? If so, get a plow for it, and then buy a rear blower. The ATV is REALLY fast for up to 8" or so, depending upon how wet the snow is.
I got the rear blower for my Kubota BX25 because it was less than half the cost of the front blower, and yes, I do use the FEL a lot. And, if looking backwards is a problem for you, there are lots of great rearview camera options. (Check out the TBN threads on this.)
Good luck, and enjoy the new tractor and new home!
   / GC1705 - snow removal near Denver #18
Have you considered a UTV?
Thanks for the ideas. Not going to be buying an ATV or UTV, since one of the primary reasons of buying the 4WD tractor was to be able to do snow removal. The blower sounds sweet, but a bit hard to swallow at $4000 (that's what the dealer quoted) for a new one, given I only spent $9K on the tractor. I may try to adapt a used John Deere plow to it, if I can get on at a fair price... would run about 1/3 the cost of a new blade with 4 way controls. If not, then I may keep looking until I find a MF plow or blower at a decent price. it seems either would ultimately work for my situation, and if I get one used and it doesn't work well, can probably sell it an upgrade for little loss. The plow mounted in place of the bucket is intriguing, but that seems to mean you can't have the hydraulic angling of the blade. Has anyone (easily) retrofitted the MF GC's for 6-way controls up front? I'm not sure if the 4-way control uses one pump or two.
   / GC1705 - snow removal near Denver #20
Cabellas sells Woods-made new blowers for 3pt hitch for $2329. That's a 74". Gotta believe you can find new 60" blowers well under $2500. A 60" blower will handle your amount of area well in my opinion. And there are many used ones available back here in the East anyway. Woodmaxx at PTO Snow Blower Attachment | 2 Stage Snow Blower | Skid Steer Snow Blower - WoodMaxx sells a 60" pto driven for $2249 with free shipping.
Being patient you'll find one used too.
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2015 Chevrolet Silverado Z71 LTZ (A57148)
2015 Chevrolet...
telescope boom (A56857)
telescope boom...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
John Deere 1025R (A53317)
John Deere 1025R...
