GC2300 Weekend
/ GC2300 Weekend #1
loulblades
Butler County, PA
MF GC2300/GC1725
Took a 3 day weekend and spent most of it on the tractor. Moved about 24 tons of topsoil, tore out a bunch of brush and trees, dug up stumps and generally had a blast.
Added a 5' blade to back. Makes smoothing out topsoil much easier.
But here is the problem, and my main complaint about this tractor. The 3 point control is in a bad spot and I continually hit it with my leg. A couple times the front loader acted bizarre; going up when I was trying to put it down etc. Then it would work. In other words; sporadic operation. It quit working totally at on point yesterday so I put the machine in neutral, set the brake(this is for all the safety nitpickers) and got off and tried it and it worked. Finally realized that my leg was hitting the 3 point control and it appears that if it is out of the home position for any length of time, the front loader starts acting erratic. And the longer it is out of the home position, the more erratic it gets. So now I listen for the "whine" of the hydraulic system to remind me to keep my leg off the 3 point lever.
Other than the 3 point issue, the tractor performed quite well. Even to the point that my wife agreed it was money well spent. And that's sayin somethin.
/ GC2300 Weekend #2
All right loulblades! That is a good feeling of accomplishment 3 days of productive tractoring,nothing hurt or broken just clearing brush and moving dirt ,Doesn't get much better than that /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif
/ GC2300 Weekend #3
"But here is the problem, and my main complaint about this tractor. The 3 point control is in a bad spot and I continually hit it with my leg."<font color="blue"> </font>
I have experienced the same issue with mine and was thinking about putting a stop on the lever so that it would only raise so high and not cause the relief valve to buzz. Have you done anything like that with yours since your post?
/ GC2300 Weekend
The only change I did make was putting a beefier spring on the the 3pt control to get it to return to center quicker.
/ GC2300 Weekend #5
</font><font color="blue" class="small">( The only change I did make was putting a beefier spring on the the 3pt control to get it to return to center quicker. )</font> <font color="blue"> </font>
It seems that the only time I push the lever up with my leg is when I turn around to back up. I installed a couple of small fender washers (w/screw & nut) between the lever and the upper distance, thinking that perhaps this would stop the lever from going all the way to the top, which it did. But, it also stopped the lever from moving up enough to activate the hitch system.
I wonder if MF would be interested in letting us try out their new model designs for evaluation and feedback? /forums/images/graemlins/cool.gif
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
