GC2310 question
   / GC2310 question
Red your snow blower is it 3pth or front mount and how wide is it...cag
   / GC2310 question #12
Hi Cag,
it is the front mounted MF2360 @ 50". Took 5 mins to take off the other day (felt is was finally safe to do so). Took longer to reroute the wire from the electric chute under the hood and tie it down for the summer (another 5 mins). I like this arrangement since the front end can also be used for a blade should I have that requirement. The only gotcha is that you have to have the grill off to attach the quick mount...4 bolts - another 5 minutes or so...so about 15 minutes to remove.
Moved a lot of snow this winter and it worked well. Had a similar unit on my previous sub-compact unit (same manufacturer) and so I was not disappointed.
   / GC2310 question #13
Hi Again Cag, if you already have the 2310, a rear snowblower would likely be the best combo - loader in the front and blower balancing out the back - best of both worlds - depending on your removal requirements ie: tight spaces, vs long open areas etc..My need was for a long driveway and two larger parking spaces in front of the two houses on the property - wide open so front mounted was my best option.
   / GC2310 question
REd I don't own any tractor yet I did get a good quote for the GC2310 TLB only 20000 + taxes not bad, lot's of choice out there I just need to figure it out.. I know what my use will be I'm just a little confuse thanks for the reply...cag
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
