gc2410 backhoe problem
/ gc2410 backhoe problem #1
soccerstyx11
nottingham, nh
massey ferguson gc2410
I have a gc2410 massey ferguson compact tractor with a backhoe attachment. I used it last month and then went to go use it this weekend and ran into a problem with the backhoe. I started up the tractor and emptied the loader of water with no problem but then went to go move the backhoe and it would not move. It sounded like it wanted too but would not like it was locked or something. The hydraulic hoses move when I use the levers like hydraulic is pumping through the lines. I would greatly appreciate any help if anyone knows or has any ideas what is happening.
/ gc2410 backhoe problem #2
Check position of three point valves and any valves isolating flow to backhoe.
/ gc2410 backhoe problem #3
Check any QD in the circuit.
Reset or replace.
Thank you guys! It turned out to be that the three point hitch was still ingaged so it didnt send hydraulics to the backhoe. Thank you guys again for the help.
iDrive TDS-2010H...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
QA Pallet Forks (A64127)
QA Pallet Forks...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2010 Deere 318D (A60462)
2010 Deere 318D...
