gc2410 backhoe removal and install
   / gc2410 backhoe removal and install #11
i think that if you have to grab a hammer and beat on something on one of those tractors, maybe you should hit your head before anything else.:D :thumbsup:
far as the seat goes, i always spin mine from the side opposite the loader controls... usually takes about 2 or 3 seconds... easy peasy:)
Congratulations on having one where everything works and fit well from the get go.
It is very ignorant of you to suggest that you know how well every part of every one of these tractors fit when it was made, based on your experience.
I spent my life, and made a good living, repairing vehicles after they have been damaged. So sorry, I do know when something fits and works properly, and when it doesn't. And, I also know how to fix it, which I did.
   / gc2410 backhoe removal and install #12
i prefer to give my head a shake before grabbing a hammer, of course it took me a few decades to figure that out... guess i'm not the only one.:laughing:
   / gc2410 backhoe removal and install #13
Mine was difficult to come off-being the first time I had done so in a year and a half. When I put it back on I am going to dab some grease in the cradle to see if this helps.
As for the seat-you just need to find a way to turn it around without fighting it. I learned the more you fight it the harder it is to turn around. There is a way to do this without using any force.
As I recall I unhook the seat bracket and raise it up as is. When its as high as it till be ifor the BH position-then turn the seat 180 degrees. Then push it towards the BH side and latch it in.
   / gc2410 backhoe removal and install #14
Some of you don't seem to realize that all these tractors are not exactly the same.
As I said, if it is properly aligned, it works great. If not, you can do what ever dance you want with it, there is no way to latch it, with using force. Ask anyone who has one that is misaligned.
After I adjusted mine, it went from difficult to working like a dream.
   / gc2410 backhoe removal and install #15
So you guys with the backhoes I was wondering if any of you guys use Pats quick hitch, and if they can stay on while you install backhoe? Thanks
   / gc2410 backhoe removal and install #16
I would not count on that, there is very little space.
It's hard to get the three point arms back in there to start with.
   / gc2410 backhoe removal and install #17
I have them on my 2310, I removed the rear metal piece between the fenders to get enough clearance .
later I removed the rear lip on the backhoe foot rest area to keep the bolts on the pats from snagging .
if you keep the bolts as short as possible . you my not have to do that to the foot rest.
I did it because they snagged while I was removing the hoe at a job. and couldn't run around for shorter bolts to prevent it from happening
again.
it's very tight .but will fit.
2012 Big Tex 14ET-20BK 20ft 7 Ton T/A Flatbed Trailer (A55852)
2012 Big Tex...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55852)
2004 Pierce Tilt...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
Push Mower (A55973)
Push Mower (A55973)
Bush Hog 3715 (A53317)
2002 Alumitech Airboat with T/A Boat Trailer (A55853)
2002 Alumitech...
