GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #1
rjmack
Platinum Member
cariboo wagon rd
GC2410
I have finally given up on having the tach/hr meter working in the winter. The tractor is always stored inside heated garage, I take it outside and within 10 minutes the tach buries itself and starts howling. Stop machine, restart, rev up, tach buries and howls, repeat procedure until pissed off enough to break something.
I have put methyl hydrate and light oil down the drive cable, had it to the dealer where they re-routed it claiming the problem had been solved... nada.
The only thing that seems to work is just disconnecting the drive cable from the tach head and leaving it at that.
I am beginning to suspect the problem is water in the tach head rather than moisture in the drive cable.
btw, just had a glimpse of the 'new' gc1700... I dont see anything different regarding the tach head or drive.
I still love my gc, but not really impressed with disorganization/incompetence at massey ferguson/agco. There is no excuse for this problem not to have been solved yet.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #2
Have you tried to lube the tach head itself with a bit of WD-40 or the likes? Does your tach panel fog up when using? Has the tachometer cable been inspected or replaced?
I've had good sucess with other machines removing the cables, blowing compressed air through and working lube through. Some I've even made an adapter to push grease through with a grease gun.
I would hold off on shunning AGCO just yet. I'm not sure disorganization & incompetence really has anything to do with your tachometer freezing. They probably aren't aware of the handful of issues in the extreme cold. Your dealer should be the one to help you with cold weather experience and knowledge.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #3
I would suggest removing the cable, clean the cable of all oil and grease, flush or wash the inside of the cable housing out with brake clean and blow out everything with compressed air. Then lubricate the cable with graphite lubricant. I would suggest wearing rubber gloves when applying. It is black and will stain. You also need to inject some lubricant into the tach head where the cable enters. Check both ends of the cable. Insure they are square. It does not take much to round one of the ends and then a small temperature drop will actually make grease or oil provide enough friction to cause the cable to start slipping.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #4
I'm gonna do one better then this advice -- follow gator steps and THEN wrap the cable with foam. Perhaps with one of those large weatherstripping gaskets that is hollow inside. Reason is the foam should help reduce about of condensation from forming.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #5
Definitely graphite, it can't be affected by the cold.
WD-40 evaporates too quickly to be an effective lubricant.
The only other thing I would try is here is Lubriplate Aero grease. It's good to -70*F
Aero - Lubriplate
Still not wishing I had a tach on mine. ;)
I appreciate the responses, but I'm done screwing around with the cable, it has already been off, cleaned out, lubed up enough times. The cable seems to spin just fine anyways, it's only when I connect it to the tach head that the problem starts. and that only happens when it has been outside long enough to freeze up.
I think it is most likely a poor seal or complete lack of a seal somewhere in the tach head/ dash assembly. this is a very common problem with gc2410/gc2610 series tractors. I have let it slide patiently waiting for mf/agco to come up with a fix... evidently the 'fix' involves bs'ing owners into thinking it is just the cable, long enough to get them out the door of the dealership, while mf/agco waits until enough time has passed to declare it an obsolete issue so they don't ever have to fix it. I wish they would just figure it out and make things right.
far as wd40 goes, I learned 25 years ago that it is a solvent, not a lubricant. it is basically the same as diesel fuel and though it may have some minimal lubrication properties, so does water, and here we are, back at the beginning of the problem again as soon as that water gets taken outside and freezes.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #7
My tach cable has started acting up again also. I tried 80/90 gear oil........no good. I tried chain lube, and it appears to have quit working now. ( but it did work most of last winter).
Mine acts up when it's cold. It appears that the engine fan pulls the air thru and 'freezes' up the cable. I get no condensation im the tach head as was asked earlier.
Whatever the reason, the problem stops when I disconnect the cable from the tach head.
Maybe the problem is too small a drive cable diameter? maybe something else, but whatever it is, mf/agco should have come up with a fix by now.
How many other tractors only work when it's warm out? (and are still in business)
I think what I'm going to do is post a video of a howling gc2410 tach doing a conniption on youtube and then prospective gc2400 and gc1700 series owners decide if they want to put up with the same sort of problems.
btw, if you guessed that my dissatisfaction with mf/agco is a result of seeing that mf/agco has rebadged the 2400 without fixing the problem on my machine, a problem common to these machines, a problem that has existed since I bought it new, then you are right.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #9
On my gc2610, I had the same problem. The problem was behind the tach where the cable comes in and the gears comes together. There would be enough moisture in the "grease" to cause it to freeze up. I would lube it with a very light weight grease and would have no problems.
   / GC2410 TACH DRIVE STILL A PROBLEM IN SUB ZERO #10
looks like you might want to convert to a digital tach like the BX kubota's
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
toro turf sweeper (A50324)
toro turf sweeper...
