Mowing Gear lube leaking on mower gear box out of vent
   / Gear lube leaking on mower gear box out of vent #11
My RCK60-24B deck does the same thing. The amount of lube lost is very minimal and other than the mess, I wouldn't let it be a concern!
   / Gear lube leaking on mower gear box out of vent #12
My LX4 vents a little oil at times.. BUT I think I would rather it vent out the breather tube than build up pressure and blow oil out through the seals
Brian
   / Gear lube leaking on mower gear box out of vent #13
I have 2 woods mowers and both of them done it. If you take the vent out and look at the check valve in them, they are real strong to open.
What I did was to put a 90 deg. tube fitting in. Ran a clear hose up the 3pt. frame pointing down to keep water out, put a filter on the end to keep out dirt and bugs. Now if it comes out it drains back into gear box and not all over my mower.
   / Gear lube leaking on mower gear box out of vent #14
Here is the best solution. Simple and effective!
Deano
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
378505 (A51573)
378505 (A51573)
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
