Gear oil capacity for Bush Hog SQ600?
   / Gear oil capacity for Bush Hog SQ600? #1
2dawoodz
Bronze Member
I can not find an online manual for the SQ600. I changed the gear oil and added 2 quarts of 80w90. The oil level is approximately 1.5" from the check hole. Is this sufficient amount?
   / Gear oil capacity for Bush Hog SQ600? #2
Google SQ600. You will find them.
Sent from my iPad using TractorByNet
I have. The only owners manual I could locate was for models SQ142, SQ148, SQ160, SQ172, SQ184, SQ84T. The SQ160 has the same overall measurements so I went with the same 2 quart capacity.
   / Gear oil capacity for Bush Hog SQ600? #4
You should be fine. Most lesser brands that use a universal gearbox use a little less than 2 quarts.
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
AGT QH12 Mini Excavator (A50322)
AGT QH12 Mini...
