Gear pump hose ?
   / Gear pump hose ?
Yes, but that is the "return to pump" line coming from the sump. Yes, low pressure, but it is also a 'low' spot.
You could try the shop vac trick to prevent a lot of fluid coming out. You'll still get some flowing out, but it could reduce the amount you loose considerably.
OK you confirmed everything I was thinking the low spot, the vacuum trick, etc. thank you for replying that
   / Gear pump hose ?
The vac trick worked well , I did not lose one drop. Even after shut off no fluid loss which I find odd and system was full. Found out dealers dont stock return hoses so just go get a section at NAPA. Now if I can just get loader to line up again lol.
2010 INTERNATIONAL LF627 SLEEPER (A56138)
2010 INTERNATIONAL...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
Scag STT52V-27CH 52in Zero Turn Mower (A55851)
Scag STT52V-27CH...
Horse Weathervane (A55853)
Horse Weathervane...
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
