gearbox issues jd2040
/ gearbox issues jd2040 #1
jumbe08
moneggetta
jd 2040
Hello everyone I have a problem with the gearbox of my jd 2040 in second range 5th and 7th gear the just keep going kicked out underload anyone had the same problem yet
/ gearbox issues jd2040 #2
No experience with that tractor, but I had a '49 chevvy that repeadedly kicked out of high gear at highway speeds. It was caused by a worn bearing on the input shaft. a replacement tranny from a scrapyard did the same thing, for the same reason. Might be a bad bearing in your tractor tranny, or a worn shifter fork, Spiral cut synchromesh-type gears are more prone to kick out, too, if they are a bit worn or the shaft is loose in the bearing. Most tractors use square cut gears, however. They are called "dog" gears and cannot be shifted unless the tractor is stopped.
Hence the name "crashbox" tranny.
/ gearbox issues jd2040 #3
:welcome:
To the forum.
/ gearbox issues jd2040 #5
There are spring loaded balls and detents on the shift shafts. Maybe the springs/balls are rusted/gummed up not keeping the shaft in position.
Do you guess that I should split in half the tractor or I can something just remove the top lid of the gearbox?
/ gearbox issues jd2040 #7
I think I'd suggest to remove rockshaft housing(3 pt) and inspect gears and shifter rail detents.
/ gearbox issues jd2040 #8
TxJim beat me to the reply. I agree, pull the rockshaft housing, no need to split at this point.
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
18.4-38 Clamp On Rear Duals w/Rims (A64119)
18.4-38 Clamp On...
2012 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2012 Ford F-150...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
100 GALLON L SHAPE FUEL TANK W/ 12V PUMP (A64276)
100 GALLON L SHAPE...
(3) 100 GALLON FREON TANKS (A64281)
(3) 100 GALLON...
