Gearbox oil change for deck and one other question
   / Gearbox oil change for deck and one other question #11
After a bit more thought, the "technical" comment probably refers to the bottom seal. In order to change that seal you must remove the gear box and that can be a pain. However, it's that seal which is more likely to be the culprit in a catastrophe. It's easier to have an undetected oil leak because of the center pulley and grass clippings and debris obstructing your view.
I wouldn't change the seals unless there was a reason UNLESS you know you won't check them periodically. If it starts looking oily and goopy around the bottom of the gear box check those seals!
I think that's the one he's talking about.
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2015 John Deere 5085E (A53317)
2015 John Deere...
2018 Ford F350 (A55973)
2018 Ford F350...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
MIVA VA115 MINI EXCAVATOR (A57192)
MIVA VA115 MINI...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
