CoyPatton
Veteran Member
- Joined
- Aug 10, 2015
- Messages
- 1,601
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
Of course you know to stop the tractor movement to engage and disengage the diff lock. Never used brakes to take pressure off the diff lock but have placed in reverse and remove the load off the lock. Just ease back pulling the diff lock up. May have shifted back to forward also. Odd, when you develop your habit on such remembering it step by step is not that easy.
Great info for operating a properly functioning diff lock. Under the conditions that were described by the ‘new to me’ owner in the OP, this procedure did not help. Once his is back to functioning, he should follow your recommendation, but on the current status, he needs to get the mechanism sliding as designed.
Worse case, he will need to take the top off as Winston1’s photo shows and id and correct the issue. Mine and another’s suggestion to use it often and get it disengaged (however he needs to) is an effort to hopefully get it properly functioning with a few uses and not require taking it all apart.
