downslope
Platinum Member
- Joined
- Mar 11, 2008
- Messages
- 642
- Location
- NY
- Tractor
- MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
No, not a CDL for interstate, it doesn't say that. But if the GVW of the truck added to the GVW of the trailer is over 10,000, either from actual scale weights or adding the vehicle specs together then you need DOT registration and numbers and business name on the truck, plus whatever else might go along with that. And in more than half the states you need the DOT reg for intrastate business as well.Thanks, so, for example - since per Ford's web site specs EVERY F150 has greater than (>) 10,001 GCWR they all require a CDL if used in interstate commerce.
Is that correct?
Even at least 1 Ford Explorer would qualify.
Only when the total goes over 26K does a CDL come into play, and even then if the truck is 26K or less and the trailer is 10K or less you still don't need a CDL. A 25,999 truck can pull a 9,999 trailer and the driver does not need a CDL.
