General Minnie-Mo G1000 questions
   / General Minnie-Mo G1000 questions #1
GSS
Pgh, PA
Cub Cadet 7360SS, MF1100 & JDx585
A friend and I are looking at a 1967 Minneapolis-Moline G1000 diesel at a local dealer. I spoke to the previous owner and they seem to have taken great care of it. After driving it, I have a few concerns (besides the fact that it might be hard to find parts for).
It's sometimes hard to get into or out of gear. The clutch seems strong, so could it just need adjusted? How hard is it to do?
The PTO shaft is always spinning ever so slowly. I haven't tried to grab it to try and stop it, nor have we hooked up anything to it. Are those plates difficult to change? Are they hard to find/expensive? Could it be something else?
What should the pressure be at the hyd remotes? They said they'd test it for me, but weren't sure what the proper pressure should be.
Amplitorque seemed to work. Tach and a few other guages don't work. Lights don't work.
Anything else prone to breaking on these that I should pay particular attention to?
They're asking $5900.
Thanks!
- Gerald
   / General Minnie-Mo G1000 questions #2
Wife's granddad had one of these. His had a waterpump leak that he couldn't fix. Most likely it was his skills and not being able to find a replacement gasket kept it leaking.
I'm not sure, but I think the PTO will drift a little when not engaged and not hooked to a PTO implement.
Good luck.
ron
Good thing the previous owner rebuilt the water pump right before trading this one in!
I suppose older tractors like this could have the drifting PTO issue. I guess I'll just have to have them hook it up to a mower or something to see if the extra resistance will be enough to keep it from spinning. PTO's are dangerous enough. I don't need the added threat.
8Yd Dumpster (A44571)
2006 JLG 2030ES 20ft Scissor Lift (A44571)
2006 JLG 2030ES...
2018 Bad Boy MZ Magnum Zero Turn (A44391)
2018 Bad Boy MZ...
2012 AMERITRAIL, INC. 30 T/A GOOSENECK TRAILER (A45046)
2012 AMERITRAIL...
2015 Heartland Wilderness 3125BH Camper (A44391)
2015 Heartland...
3000 Gallon Black Poly Water Tanks (A45336)
3000 Gallon Black...
