First of all an alternator is a generator that produces alternating current called AC. Old cars had what was called a generator and produced direct current called DC which fed the system to keep the battery up and supply other items with DC.
In a modern car the generator produces AC and it is then converted to DC through a rectifier using diodes. The system must have DC to operate. However the DC produced this way is not a flat voltage but is actually a pulsating DC which is smoothed out by the battery maintaining a steady voltage.
The reason cars and trucks went to AC generators is because the brushes now only need to sustain a field in the armature which is a lot less current [amperage] than what is needed in a DC generator. In a DC generator the brushes had to carry the full load of what was being produced and they would not last very long.
The term alternator came into common use to describe a generator which produces AC and then converts it to pulsating DC.
I hope this is not too much more than you wanted to know, but I know most people do not realize that an alternator is a generator going by a different name. Some modern parts list will still refer to the alternator as a generator.
I know this probably does not answer what you are trying to determine, but all modern generators are of the AC type because DC generators could not easily produce the needed wattage for today's applications.
What you need to determine is if your generator, or alternator if you prefer, can maintain the needs of your system as pointed out by
B2400 in the previous reply.
Daniel
