Getting BX Ready For Winter
   / Getting BX Ready For Winter #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
I have documented the process of getting ready for winter with the BX. The process is as follows.
MMM removed and now need to remove the canopy. 12 bolts to take off to remove the canopy.
Sims cab on the dolly getting ready for lift
Snowblower on dolly
Jig I had made up based on Larry from mower axle design
Jig attached to the Sims cab
Hoist I added to the garage, from Harbor Freight, makes this a one person job. Total cost to install was about $100 2 years ago.
Sims lifting to top of the hoist
Cab in place, now have to bolt into place. 12 bolts to put into place and tighten.
Have to remove the handles on each side of the cab
Handles removed
Grill guard has to come off, 4 bolts
Front PTO being lifted into place
Front PTO in place, make all connections to rear PTO, install shield to front connection to protect the oil pan, 2 bolts
Rear blade connected to the weight box. Weight box is from a Case tractor and blade I got off E-bay for $25. I use the blade to move snow away from the garage doors. Then use the snowblower to get the snow out of the way.
Rear blade on the tractor
Ready for winter
Total time 2 hours, I did not rush and took pictures of each step.
   / Getting BX Ready For Winter #2
Good plan & implementation. Dollies & a hoist do make it easier :D
What about the setup of the heater?
The heater stays on the lower section of the cab all year long. All I have to do it open the valve to let water to the heater. See attached picture.
   / Getting BX Ready For Winter #4
Do you make house calls? I sure could use some help. Too much to do and not enough time to do it. I will probably be putting the snowblower on along with the cab when it starts snowing. Even then, if they are predicting only a dusting, I will possibly put it off for another day. :D
   / Getting BX Ready For Winter #5
BX Winterization Procedure in Texas:
1) Remove soda from cupholder.
2) Place steamin' hot cup of coffee in cupholder.
I can upload photos if y'all need 'em...
:D
   / Getting BX Ready For Winter #6
About the same here Russell ... still in shirt sleeves by noon :D
   / Getting BX Ready For Winter #7
How about anti-gel if its stored unheated.. That hoist is excellent!
   / Getting BX Ready For Winter #8
Here it is a week later and I still haven't gotten to it. I can't ever remember a fall that was snow-less like this one. I hope to get to it tomorrow, but who knows what will distract me?
Dusty
   / Getting BX Ready For Winter #10
None here in michigan as well. What a strange winter it has been so far for many of us.
   / Getting BX Ready For Winter #11
Sadly there is nothingin PA. Got my dipstick heater ready to go and put Diecel White in the tank. Well, I don't mind the fuel oil bills this year. :)
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
DEUTZ MARATHON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Alamo SHD96 Flail Mower
Alamo SHD96 Flail...
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
