Teikas Dad
I'm not going to say that my wife is short.....let's just say that she's vertically challenged. This presents a problem when she's operating the tractor (B3200) as her leg is not quite long enough to fully apply the brakes from a normal seated position. To push the brake all the way down she has to slide forward in the seat to get close enough which I don't think is particularly safe.
The tractor has the reversing seat mount for use with the backhoe. I've got the slider adjustment as far forward as it will go (it's actually a good spot for me to operate from and I'm 5'11"). Here's a photo of the mount.
If I could get the seat to slide forward another 2 inches it would make a big difference for her. There are other holes in the bottom of the seat but they don't have the same spacing dimension as the bolts holding the silver plate on. I thought about moving the seat on that bracket, but that seems to be a no go.
The track section that attaches to the seat is 11 inches long.
Does anyone have another model tractor that has a longer seat slide than this? If so I may be able to buy the parts and retrofit mine to get a little extra forward movement.
If anyone has any other ideas, suggestions or if you had the same problem and you modified things, I would appreciate hearing from you.
