GL 40 series pto question?
   / GL 40 series pto question? #1
lawn_king
Veteran Member
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
Do you use the clutch when you engauge/disengauge the pto?
   / GL 40 series pto question? #2
I own a 3240 and always use the clutch to engage the pto. I typically do not use the clutch to disengage.
Thankx. My salesmen, long time tractor guy, 2910 owner himself, told me to clutch?
   / GL 40 series pto question? #4
The clutch on the floor has nothing to do with engaging/diengaging the pto the Grand L GST MODELS. The little pto lever behind the seat does all the work.
   / GL 40 series pto question? #5
I have the same 3540 and the clutch does disengage the PTO but it is not necessary. Just idle down and engage PTO level under NO load and then throttle up and go to work.
2010 Dodge Grand Caravan (A50324)
2010 Dodge Grand...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
7021 (A50322)
7021 (A50322)
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
