Glow Plug Indicator
/ Glow Plug Indicator #11
The glow indicater is has a specific resistance so the glow plugs receive the correct voltage. You don't have the right resistance & may end up burning up the glow plugs. I recommend buying the correct part.
/ Glow Plug Indicator #12
The wire has to be the same dia and lingth. If it is smaller it will heath up to fast. If it is too big It will put to much voltage to the plugs and burn the plugs out. If the piece that was brokeoff was touching the engine that is what could of caused the probblem.......Larry
/ Glow Plug Indicator #13
disconnect the wire to the first glow plug and tape it so it does not touch any metal then try it.if it still glows it could be u have wire problems if nothing happens the problem is the wire may be too thin or the plugs shorted somehow.
/ Glow Plug Indicator #14
Try a paper clip, wind it up on a pencil or whatever leave a slight gap between the turns, ( I'm thinking they are 10.5 volt glow plugs, if not order the correct resistor. check your voltage at the glow plugs with a digital meter when done. It should read 10.5 Volts DC. If voltage is lower, cut off some of the paper clip. If it's a little higher than 10.5, then don't leave them on quite so long. Boy am I going to catch flak for posting this.
/ Glow Plug Indicator #15
I would listen to Lens12 and purchase the correct part. It isn't just about the size and length of the wire, it's about wire composition, resistance and what it's designed to do. If you live in Mexico and don't need your glow plugs, fine, but if you are like the rest of us where they actually are needed, take Lens12 advice and replace it with the proper part.
I purchased a new/used glow plug indicator and still having the same problems. I was careful not to burn the indicator, $30.00, so I turned key to heat plugs, indicator heated way to fast again. I have not checked the voltage along the bar, but for sure I'm getting way to much juice going thru the indicator. I can start the tractor using a block heater, but have to rely on my starter more than I want. I'm not the best when it comes to anything electrical, so any comments would be appreciated.
Eddie
/ Glow Plug Indicator #17
Have you unhooked both glow plugs & tried the switch to see if you have a short some place?
/ Glow Plug Indicator #18
repaired my burned out glow plug indicater with steel welding wire, ruined four new glow plugs , bought another four new glow plugs and a new indicator, somtimes we learn the hard way
/ Glow Plug Indicator #19
I'd also like to know what the part number is and where to get it. I am getting 12V to my glow plugs also. On Iseki a TL2300.
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
HYDRAULIC TANK WITH COOLING SYSTEM (A60736)
HYDRAULIC TANK...
2018 Nissan Sentra Sedan (A59231)
2018 Nissan Sentra...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
FUEL CELL (A58214)
FUEL CELL (A58214)
