Glow plug relay and timer
   / Glow plug relay and timer #11
Thanks all. I am going to order a Kubota timer on EBay and put it in. I really appreciate this forum and all the input!
   / Glow plug relay and timer #12
Thanks gents.. I ordered the Kubota timer on EBay, 9.99$ plus 2.99 shipping. Will post here if it does not do the job. As a new user, kudos to you all for the input and help with my problem. I am sure you will here more requests from me in the future, although I hope not to frequently.
   / Glow plug relay and timer #13
A big "thank you" for all the contributors... helped me to find the "glow plug relay" and "timer" (for the longest, I thought these were the same item. I finally understood that I could pull the relay, take it to the auto-parts store, find a replacement (about $9); and plug the new one in (I also ordered the Kubota glow plug timer off e-bay for about $25). But, changing the "relay" fired up the glow plug (and lamp on the dash). yay.
BIG THANK YOU...
   / Glow plug relay and timer #14
Hi. Just wanted to say "thank you" to the contributors. (and thank you, posthumously, Jinman)... as a "novice" (we're all a "novice" at something, right?) I was trying to understand difference between the "relay" and the "timer" (whenever I searched "NH TC40 glow plug relay" -- it went to the "timer"). So, I finally figured out the "relay" is a commonly utilized item that I was able to pull and take to the auto parts store ($9) ... and it did the job. (glow plug indicator now comes on, on the dash; goes off in 10 seconds or so and tractor starts more easily when cold). I had also ordered the "kubota timer" as above, for $25, and will have it as a spare part going forward.
BIG THANK YOU (all) for the help...
   / Glow plug relay and timer #15
A timer counts down or up to create a time interval, a relay (usually) is a snap action switch (off/on) with no delay and uses to switch high current loads, usually controlled by a low current switch or timer.... Yes there are exception to this as some will point out that a timer and relay may be enclosed in same housing....
Dale
   / Glow plug relay and timer #16
This thread sure helped me . Having a glow plug issue and this got me going on the right direction. When I tore in to my tractor the timer had been removed. Parts should show up tomorrow or the next day .
2014 MOROOKA MST3000VD TRACK DUMPER (A52705)
2014 MOROOKA...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
