Glow plugs and resistor
   / Glow plugs and resistor #31
Would like to know if Hoka Hey found the real problem. I'm having the same thing going on with a TU 1700. I have three (3) new glow plugs, but have not installed yet. I'm getting 9v between the first and second plug. Have not checked any further. I can start with help of block heater, about a 45 minute process. Comments appreciated.
Eddie
   / Glow plugs and resistor #32
When you remove the old glow plugs, look very close at the side and see if you can find a voltage marking. I ordered some for my tractor and they came through as 5V, they should have been 9V. I finally after much research replaced the glow plugs with a 12V version don't need a resistor with these.
Max
   / Glow plugs and resistor #33
By coincidence i had a similar problem this weekend on my TL
First indication was a much faster glowing resistor and a glow moment between off-position and AC position of the key switch.
Then the resistor burnt.
Long story with a lot of stress short:
The black-white wire to the bus grounded itself due to vibrations. This resulted in the burnt resistor but before that a too high current draw through the feed lines to- and the key switch.
I had to replace the main feed connector that fits between dash and the feed line coming from the starter. (burnt also and giving spooky measurements before we found it)
So, with a new keyswitch in place and the resistor bridged (i do have 12V plugs). Tractor was back on the road.
Just as a confirmation:
- Glowplugs have 2 connections to key-switch: 1 pre-heating and 1 starter contact. (both wires being black-red) so yes plugs are heating when starting tractor.
- Currect draw has to be between 15 and 27 Amps dependin on temperature of engine. Cold engine takes 27 amps, hot 15 amps.
a last remark,..
The starting circuit is not fused (starter and glow plugs). The resistor is not a fuse.
IF a cable shorts before the resistor cables will burn quickly.
Therefore my advice to put a battery switch on your main cable and switch off the electrics when parking your tractor.
Melting the connector took 2 seconds and that could have happened during the night or at any given time. The only thing that can stop a fire in that case is disconnecting the battery.
   / Glow plugs and resistor #34
I have removed them before and they are 9v plugs. Where did you find the 12v plugs for your tractor? I will also check and wire from starter to see if it is fried.
Thanks for the input.
Eddie
   / Glow plugs and resistor #35
Gilbertmsg,
I bought my tractor 1.5 years ago refurbished by a belgian company, one of the things on their list is replacing the glowplugs when rebuilding the engine. So sorry no clue where to find them other than this guy.
mods, remove if inappropriate, their site is microtractrors.com.
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2016 INTERNATIONAL PRO STAR TANDEM AXLE DAY CAB (A58017)
2016 INTERNATIONAL...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
49205 (A55788)
49205 (A55788)
