Glow plugs JD 4200
   / Glow plugs JD 4200 #1
gregmartin
Hudson Wisconsin
John Deere 4200, John Deere 997 Z-Trak
How do you check glow plugs & block heater on a John Deere 4200. I got it started at 15 below zero ( barely ) I'm thinking it should have started a lot easyer. My diesel vw sits at work 11hours a day not pluged in and it starts no problem.
   / Glow plugs JD 4200 #2
There are no glow plugs in your 4200. It is a direct injection engine. I have the same exact engine in my 4115.
If you don't run it every day, it can be a bit hard to starting temps that cold. Make sure you have a good battery in it. I replaced mine a couple years ago when it was getting hard to start and it made a huge difference.
Is it ok to use starting fluid.
   / Glow plugs JD 4200 #4
I know some guys do, but I never do. I don't think it's wise to do on thee little diesels. Make sure your fuel isn't gelling on you. take a look at the fuel in the filer bowl and see if it is solid looking or still nice a clear and liquid. I always use a cetane booster/anti gel treatment in my fuel once temps get to 40 degrees or below
I think fuel is ok, I use blended fuel from holiday station. I usually don't use it all winter, I can get by with a regular size snowblower. But this year I needed the front end loader.
   / Glow plugs JD 4200 #6
Well, it sure won't hurt to check it. I never trust anyone else to make sure my diesel fuel is ok.
   / Glow plugs JD 4200 #7
I don't know what year your vw is but they have an automatic glow plug system that works very well. Your 4200 does not have glow plugs but has a heater in the intake manifold. If you push in on the key in the on position you should have a light glowing in the dash. You should then also have power to the wire going into the intake manifold heater which is just below the fitting that the intake manifold hose from the air cleaner attaches onto. If you push the key in long enough and the manifold heater is working it should get warm to the touch. If you plug in your block heater it shouldn't take too long before the block starts to get warm. You can also use a volt meter to check the wires for continuity. If you have to replace the block heater it's not to bad a job. I take off the alternator to give myself a bit of extra room. Have the new one ready with Teflon tape or some other sealer and just unscrew the old one and screw in the new one. I do it with a cold engine and I don't drain the antifreeze. If your half ways quick you don't really loose enough antifreeze to warrant draining it. Hope that helps.
I thought pushing in the key heated the glow plugs,I will take your advice and check those out. It does sound pretty easy to check. thank you very much.
   / Glow plugs JD 4200 #9
If you're using the inlet manifold heater using starting fluid may make for a big surprise.
   / Glow plugs JD 4200 #10
I agree with you Egon. I have never used starting fluid on my 4410 so I never even thought of that. My 4410 starts very easily at temperatures as low as 0 F (-18 C) without being plugged in and just glowing for about 30-45 seconds. It's very rare that I have to crank more than 3-4 seconds to get a start. gregmartin I looked in the parts book for glow plugs. Just found a manifold heater.
2012 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A45333)
2012 KENWORTH T800...
Utility Trailer (A45336)
Utility Trailer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A44571)
2025 Kivel 48in...
Kubota ZD326 (A46443)
Mini Skidloader Trailer Mover (A47809)
Mini Skidloader...
2025 Wolverine SBM-12-72W Sickle Mower Attachment (A47484)
2025 Wolverine...
