Many of the 4WD GMs have blocks now. That only makes the twisting forces on springs worse. Blocks are never good.
Isn't going from 3 leaves to 5 leaves just adding leaves? Overloading is an obvious cause of broken springs, but another factor is spring twisting caused by aggressive braking and acceleration. When some of these guys put the peddle to the metal with ~400hp/400ft.lbs., those springs get quite an S bend in them. The blocks only make the problem worse. Adding a leaf will usually improve the situation along with better shocks for the pothole problem. Be a little careful in adding springs, as there's a lot involved with building a spring pack. Your results will vary. The idea is to cut down spring flexing and twisting. Thin leaves usually do a better job at not breaking as long as they don't get overloaded. Oh, and don't forget about those driveline angles.
That's normal with many springs. It has to do with design and ride height.
Yeah, i was being rather redundant. It seems like the 3 thicker springthey are putting in now don't flex as well and break instead. If it was my truck I would consider replacing them with an older style with 5 thinner leaves.
