GM in deep with this Ignition Switch Issue
   / GM in deep with this Ignition Switch Issue #2
Were these switches installed only on vehicles built by the "old" bankrupt General Motors? Not the new GM?
Is the US government still a major stockholder in the new GM?
   / GM in deep with this Ignition Switch Issue #3
Can't trust ANY of these Car Companies!
   / GM in deep with this Ignition Switch Issue #4
"Old" vs "New" is a joke. Companies do that as part of their sweet deal when they go bankrupt. They run a company into the ground, throwing ethics out the window along the way. Then they file for bankruptcy and declare they are a "New" company, leaving all their bills ,dirty laundry, and liability in the past. It's not just GM that has done this, but they are the most recent and biggest offender. How many decision makers at the New GM, were employed by the Old GM? Most of them.
   / GM in deep with this Ignition Switch Issue #5
Don't put five pounds of **** on your key chain and your good to go.... HS
   / GM in deep with this Ignition Switch Issue #6
   / GM in deep with this Ignition Switch Issue #7
From the testimony:
Rep. Diana DeGette, D-Colo., held up a switch for one of the cars and said a small spring inside it failed to provide enough force, causing car engines to turn off when they went over a bump.
DeGette showed how easy it was for a light set of keys to move the ignition out of the "run" position. That can cause the engine to stall and the driver to lose power steering and power brakes.
GM has said that in 2005 company engineers proposed solutions to the switch problem but that the automaker concluded that none represented "an acceptable business case."
"Documents provided by GM show that this unacceptable cost increase was only 57 cents," DeGette said.
Rep. Tim Murphy, R-Pa., chairman of the House Energy and Commerce Subcommittee on Oversight and Investigations, read from an e-mail exchange between GM employees and those at Delphi, which made the switch. One said that the Cobalt is "blowing up in their face in regards to the car turning off."
   / GM in deep with this Ignition Switch Issue #8
What does it matter now? Sound familiar. HS
   / GM in deep with this Ignition Switch Issue #9
yes , they all duck their responsibilities due to bean counters ( costs less to settle each case than issue a recall ).... the Gov should enact strict laws on this stuff ... ( a deterrent if you like ) for safety issues ...
how about 10 million mandatory penalty for EACH person killed or injured in an accident due to a "safety defect" , 1/2 to the Gov and 1/2 to the person involved..... then lets see the bean counters react to that..... plus they have to issue a recall and fix the "fault" ( and supply the affected owners with a current year model, until theirs is fixed )
   / GM in deep with this Ignition Switch Issue #10
GM's actions in this situation are reprehensible! People died and their families suffer due to the decisions of a few callous and short-sighted people. Unfortunately these people will never be punished for their actions. I doubt the company can survive this and a lot of people, who had nothing to do with making these bad decisions, are going to lose their jobs.
2022 Toro Workman 07921 Electric Utility Cart (A55851)
2022 Toro Workman...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
2016 CATERPILLAR D6N HI-TRACK CRAWLER DOZER (A52707)
2016 CATERPILLAR...
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
2020 DRAGON ESP...
2016 Mitsubishi Outlander SUV (A55853)
2016 Mitsubishi...
