GM in deep with this Ignition Switch Issue
   / GM in deep with this Ignition Switch Issue #11
I've got a 2005 Cobalt. Got the recall letter. They don't have the parts yet... so... LOL
   / GM in deep with this Ignition Switch Issue #12
yes , they all duck their responsibilities due to bean counters ( costs less to settle each case than issue a recall ).... the Gov should enact strict laws on this stuff ... ( a deterrent if you like ) for safety issues ... how about 10 million mandatory penalty for EACH person killed or injured in an accident due to a "safety defect" , 1/2 to the Gov and 1/2 to the person involved..... then lets see the bean counters react to that..... plus they have to issue a recall and fix the "fault" ( and supply the affected owners with a current year model, until theirs is fixed )
how about 10 million each, half from union who built the car half from government who owned the company. What did Obama know and when did he know it? HS
   / GM in deep with this Ignition Switch Issue #13
Interesting bit on the news last night stating the "Replacement Switch: and "Original Equipment Switch" have the same part number stamped on them. Why? Cover-up? In any event, now mechanics can't tell if a switch has been changed or not.
   / GM in deep with this Ignition Switch Issue #14
I've always been amazed this doesn't happen more often. All the Big Three automakers will drop you as a supplier for a few tenths of a cent in price on certain parts. Toyota and Honda are a bit more loyal but still price is a big driver in who gets/keeps the business. Some parts we make over 40,000,000 of a year so a half a cent a piece can add up.
How parts are spec'd can be an issue also. I remember a sister company had to make a Cadillac ashtray that was spec'd to function to 40 degrees below zero. They got it but it was hard to open at normal temps but still within force specified. Finally someone with some brains changed the temperature spec.
   / GM in deep with this Ignition Switch Issue #15
I remember about 20 years ago when some Einstein at Ford had a new wheel nut & wheel design and we made the parts to their spec. Long story short, wheels started flying off Broncos and some Ford big shot's wife happened to be driving one and got left sit along side the road in Michigan. I always wondered how long that would have went on if that hadn't happened to her. We were told hush hush but I assume the statute of limitations is over for that.
I don't feel bad for spilling my guts now, was called into ***** session at Ford and found all our parts well within design specs. Any idiot could have told them, as we did, that this was a bad design. Believe it or not, I have a Ford Escort story that tops that but another day.
   / GM in deep with this Ignition Switch Issue #16
Of course, there is no assurance that "the fix" would not just cause troubles elsewhere.
VW-Audi had a switch problem as well. The electrical portion (not the lock portion) would wear through at the spring detent. Then the entire mechanism would jamb.
The failure would usually occur when starting up. Then the starter motor wouldn't de-energize. That $15 switch would cost an unattetive driver a new starter motor in about 3 minutes.
I replaced two (two different cars) and kept a replacement in the glovebox of the '1996 A6. There is probably still one out in the shop on a shelf somewhere.
'Never even thought that it was a "defect" or worthy of recall. Stuff wears out. The part worked fine when it was new! It was general knowledge with the Audi crowd "Don't hang crap from the key chain"! That was enough. (A word, To the wise, Is sufficient!"
PIA job to replace too....
   / GM in deep with this Ignition Switch Issue #17
You know you hear various figures bandied about for the cost of retrofitting the switch.. some say $0.57. some say $2.00. but what ever the switch cost to replace would only be part of the cost as the labor cost to replace or retrofit would amount to hundreds of millions of dollars would it not? Dealer shop rates would apply here would they not? The business case could not be made for the recall because the few millions that would likely be paid out for victims would in no way equal the total amount to recall each and every one of those cars. Their bean counters did the math and made their decision. Of course the engineering department was likely jumping up and down and saying "we have got to fix this" and maybe even the marketing department too, but in the end the bean counters got the ear of the top management and the decision was made. Now they have to live (or die) with it.
What does it matter now? Sound familiar. HS
Sounds like Ford Pinto all over again. You would think these manufacturers would learn.
Chris
   / GM in deep with this Ignition Switch Issue #19
One of the kids that died was drunk and speeding and hit a wooded area...also had a big keychain. I have been telling the wife for years that she don't need all them keys on the chain. Now, she finally "gets" it and separated the car keys.
   / GM in deep with this Ignition Switch Issue #20
Could have been a combination of "Marketing" and "Bean Counters". Marketing reported that people were complaining about the switch cylinder being difficult to rotate to the start position and was hurting there little hands. Bean Counter said, hey look we can save $.57 cents by changing this spring.
As an aside, have you seen some of the garbage that people, women especially have attached to ignition keys. Some that I have seen have to weigh more than an engineer who designed the switch anticipated.
I am old enough to have experience at owning several different makes and models of automobiles and trucks. I have had problems with some, more so than others. Even had one taken back under the "Buy Back" Lemon Law. The song and dance by all manufactures when dealing with defects is basically the same, IT IS A DEALER PROBLEM. Take the vehicle back to the Dealer, we only assemble them, he fixes them.
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
