KICK
Platinum Member
- Joined
- Oct 29, 2006
- Messages
- 508
- Location
- stilinlimbo, FLA
- Tractor
- Mitsu 2000, Hew Holland 875, JD 125
gemini5362 said:I do have a question for some of the posters that are so worried about wear and tear on their engines due to oil problems. According to everything that I have read the worst oil related problem that you have on an engine is starting it after it has been sitting for a while even as short a period as overnight. During the initial time that you start it you have parts that are rotating with a metal to metal surface until such time that the oil is pumed into that region. They make electric oil pumps that you can turn the ignition key to the on position and that starts pumping oil through the system. You can leave the key on for a short period of time before you actually engage the starter motor. How many people have installed one of these systems on their vehicle ?
Start up is when the most wear occurs...
don't know anyone that put a priming system into their lube system although technically it sounds like a good idea. that said, I have a pickup truck with 248,000 miles on it, cant imagine how many time its been started.
do remember a company selling starter motors for heavy duty diesel applications that had a built in oil pump on the starter motor, just to prelube the engine before starting.
