GM Seatbelt Issue
   / GM Seatbelt Issue #11
Timber said:
We live in a strange world where every one thinks they deserve millions of dollars because there coffee was to hot or there cheese burger made them fat.
You are right on that issue. It is a strange world. We can try to blame the lawyers but they are just a symptom and byproduct of a larger problem. The root of the problem is the approach our "lawmakers" take towards governance.
We live in a country (world) where legislation is the answer to every problem; legislation is what determines our actions and responses to everyday occurrences. A sense of right and wrong, a sense of ethics and morality and a sense of commonness (aka common sense) are irrelevant; legislation is king. The problem with legislation is that it's an inexact methodology. Any law you make naturally created loopholes. Legislation is black and white and the problem is we live in a shades of gray world. And the only way to fix those loopholes is...more legislation. We can legislate till we are blue in the face and we still won't be able to predict or prevent human response and action.
So now that we have an overbearing number of infinitely complicated laws we need lawyers to help us wade through the mire. But since many people are dishonest and have no integrity they use the lawyers (who are more than willing) to take advantage of system which is easy for anyone equipped with the proper knowledge and logic to find those loopholes. "Lawyers" are just taking advantage of a system which we have created. We obviously didn't intend the system to be abused this way but we set it up, we voted for it, we created this untameable beast.
What's the solution? I don't think there is one. The other option is to scrap our heap of legislation and go with the golden rule (do unto others...) but that leaves room for judgment which leads to corruption, favoritism and all that other good stuff. Or we can try to continue the death spiral of further refining our current legislation. Choose your poison.
As for your seat belt. I think you did the right think by trying to get GM's attention and trying to let them know they might have a problem. And I'm sure there are some people at GM who are genuinely concerned. But they need to play the game. If they show concern, they show weakness and the vultures will swoop in and sue the pants off GM. So, GM circles its' wagons and quietly hopes you will just go away.
   / GM Seatbelt Issue #12
I think most of your points are well taken. However, the problem is not the lawyers and the legislature are separate groups, but that they are the same group. Basically there is a conflict of interest where lawyers who are now legislatures vote for laws that help them in their former careers and/or future careers. This creates a system of lawyers for lawyers and by lawyers. It would be silly to not have lawyers in the legislature, but it should be balanced with other professions. Also the National Trial Lawyers Assocation (I think that's the name) gives a lot of money to the legislatures.
I would like a third body of legislatures whose sole job is to eliminate laws, and only require 1/3 of those eligible to vote to allow this elimination. It's kinda like a line item veto, but done by a group. If a law is so bad that even 1/3 of the people think it is bad, then it should probably be eliminated.
   / GM Seatbelt Issue #13
Back on subject... (Don't take this the wrong way.)
I don't think you have provided enough information about the accident, it takes a bit a movement before the seat belt will latch. Did her thumb stop her forward movement prior to the seat belt catching?
I am just trying to make you stop to think about this, not trying to get more information.
Somebody posted about an airbag not going off. Did you know that there is more than the speed you were travelling at the time of the accident that determines if the air bag deploys? Did you know that a vehicle could be totalled (frontal type collison) and no air bag deployment?
Here is an excerpt from an 06 Silverado Owners manual concerning airbag deployment:
Frontal airbags may inflate at different crash speeds. For example:
• If the vehicle hits a stationary object, the airbags could inflate at a different crash speed than if the vehicle hits a moving object.
• If the vehicle hits an object that deforms, the airbags could inflate at a different crash speed than if the vehicle hits an object that does not deform.
• If the vehicle hits a narrow object (like a pole), the airbags could inflate at a different crash speed than if the vehicle hits a wide object (like a wall).
• If the vehicle goes into an object at an angle, the airbags could inflate at a different crash speed than if the vehicle goes straight into the object.
The frontal airbags (driver and right front passenger) are not intended to inflate during vehicle rollovers, rear impacts, or in many side impacts.
In any particular crash, no one can say whether an airbag should have inflated simply because of the damage to a vehicle or because of what the repair costs were. Inflation is determined by what the vehicle hits, the angle of the impact, and how quickly the vehicle slows down.
Some of the new safety features on vehicles don't always work the way that they used to, or the way they expect them to.
Kurt
   / GM Seatbelt Issue #14
Well I am of the opinion that the seatbelt should have worked correctly when needed. Seatbelts are a useless item unless you have an accident. You dont need to wait until your physical safety is on the line and then hope it works. If it does not work then someone needs to find out why. Is it just a normal equipment breakage or is it a design defect. If it is a design defect then GM needs to have a recall.
It is interesting to see the comments about lawyers and legislation from people that are not lawyers and dont write laws. A lot of things goes into legislation to make it do what the writer wanted. Not only does it have to legislate what it is intended for but it has to protect rights. We have a group that decides if a law is correct or not I believe they call that group the supreme court. Saying that we have bad laws and trashing lawyers is very similar to me saying that farmers only have to throw seeds into the ground water and wait for crops. I dont farm so from where I sit it looks easy. I am sure that being an attorney is not nearly as easy as it looks. Just like I am very sure that being a farmer is a LOT of work. If you dont like the people that are legislators vote for someone else or run yourself. I dont believe that there is an educational requirement to run for these offices.
   / GM Seatbelt Issue
Kurt
Kurt, all I can tell you is there was no prior to the seat belt catching. The belt would not retract to it's original position after the accident. It was like when you pull the belt out to buckle up but it doesn't retract against your body (the best I know how to explain it) She was going approximately 25 MPH when the guy pulled out from a business. The collision was front to front.
   / GM Seatbelt Issue #16
Billy
Thanks for the extra information. I did check to see if there was a service bulletin for the 06 trucks and there was not. (translated - no acknowledged problems)
I tried to find if that truck had something referred to as Energy Management. If it has it (I can't find it through my typical sources) the seat belt acts as a cushion to help prevent chest injuries. I have no idea if the seatbelt works as normal after it has been used. I have been hearing that it should not be uncommon to replace the seatbelt after an accident due to the stresses put on it. Are they replaced? I have not been asking that question of the body shops that I work with.
   / GM Seatbelt Issue #17
Safety mechanisms are much more complex than they were a few years ago and often don't behave as expected. In 1950 if you hit a tree you'd marvel at how little damage the car had taken. These days you marvel at how much the car's crumple zones gave to protect the passenger - even though it looks like a mess it's actually a much safer vehicle.
I'm not familiar with GM's safety innovations, but my truck's belts have explosive pretensioners. If enough stress is put onto the belt a small explosive (like used in an airbag) will deploy to help the seat belt do its job - that means that this mechanism will likely need to be replaced once it's used.
   / GM Seatbelt Issue
The seat belt will be replaced under warranty. It's non functional now (it's pulled out and won't retract).
Thanks everyone, for your comments.
   / GM Seatbelt Issue #19
You are right and I apologize for slamming lawyers. However my main purpose was to point out the inherent conflict of interest in our system with lawyers regulating lawyers. I would like to see everyone who runs for Congress be required to run a small business for 5 years, so that they could have that perspective. On the other hand, I see the mess in Iraq and I think how much better our legal system is than their theocracy (or whatever it is). It's not the lawyers acting as lawyers that is the problem. It's the lawyers regulating lawyers.
   / GM Seatbelt Issue #20
Thank you Bob I agree with your sentiments. The problem that I see with congress is not what they do for a living it is how far removed they are from what everyone else has to do to survive. How do you really understand the need for healthcare when you have free health care for the rest of your life when you have entered the legislative branch of the government. How do you understand trying to live on socal security when you get your salary for the rest of your life and you dont have to pay anything in. How do you really comprehend how hard it is on minimum wage to just survive when you are at least in the upper middle class of the nation in terms of income. I am a firm believer in term limits. That keeps someone from spending the rest of their adult life in congress and on a regular basis gives everyone an even playing field in elections. Even with all the problems that we have. I have lived overseas a couple of times and traveled overseas a lot and I still think it is better than what anyone else has.
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
UNUSED SBC90 SANDBLASTER (A54757)
UNUSED SBC90...
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
2012 John Deere TX Gator 4x4 Utility Cart (A55787)
2012 John Deere TX...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54756)
JOHN DEERE BA84...
