Going green with a 2520.... or maybe 3120.
   / Going green with a 2520.... or maybe 3120. #11
Tom,
It took me a long time to get comfortable on the hills more so using the loader but I also found out weight is everything. If I'm moving dirt with my box blade I attach 6-42lb weights on the attachment. I can say it makes a huge difference in the pucker factor department. Your going to run out of traction first anyway.
The bottom line It's going to take time for you to feel comfortable on I think any Cut. Just this Saturday I was cutting the hills sideways, I would have never done that a year ago.
Time and lots of weight is the cure for a new Cut owner.
Malvern
   / Going green with a 2520.... or maybe 3120. #12
I mow a 17 degree side slope with my 2520 and 72 inch RFM. I have non-loaded R-4 tires. Even from the first time, it never seemed unstable, however, the weight of the RFM tended to pull the machine sideways down the hill. Because of this, I was forced to run in 4WD all the time to have enough traction to move the rig. To remedy this situation, I purchased four of the 60lb wheel weights from JD and it seems to be working as I can now run in 2WD on all but the most extreme slopes and the machine does not slide sideways.
Runner
Charlotte County (A50323)
Charlotte County...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
Terms and Conditions (A47477)
Terms and...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
PALLET OF (14) CAT WALK STEPS (A53843)
PALLET OF (14) CAT...
