golden rod and other weeks in the field
   / golden rod and other weeks in the field #1
keegs
Veteran Member
The County, ME
Kubota M5640SUD
golden rod and other weeds in the field
I have what appears to be a growing infestation of golden rod and other weed varieties in my hay fields. I'm learning that with golden rod, there's no practical way to remove it mechanically, either by pulling it or mowing it, as it spreads by way of rhizomes or runners. I'm considering spot treatment of roundup or other herbicide. Has anyone had success with controlling weed infestations?
   / golden rod and other weeks in the field #2
Yep, if you're not worried much about clovers or other legumes. Crossbow at 4-5oz per gallon, for spot spray. Add a little Preference as a surfactant. Read and follow label directions and wear a mask. Cimmeron is a good choice for the tougher stuff but it will hurt your pocket book.
   / golden rod and other weeks in the field #3
My back field was infested with goldenrod. Regular mowing before it had a chance to flower got rid of it. Now the goldenrod is on the edge of the treeline but not in the field. Mowing often I think is the best control.
   / golden rod and other weeks in the field #4
If you feed the grass well the weeds will be choked out, and you get more hay, you win both ways. Weeds in a hay field are a symptom, fix the problem and the symptom goes away.
tc...I mowed about 20 acres in early July and the goldenrod and burdock in that stretch are flowering again. Not sure what you meant about regular mowing, but my situation is such that I won't be able to mow all 50 acres more than once a year.
Ed, the hay isn't producing any income and so I can't justify the cost of fertilzer and/or lime.
I'd rather not use herbicides but don't know if there's any alternative given the circumstances.
   / golden rod and other weeks in the field #6
Ed is correct and tcreeley is correct......to an point. Many "weeds" will indicate a particular soil condition i.e. low fertility, low pH, compaction, poor drainage, poor seedling stand, drought, etc. Many "woody" stemed "weeds" can be controlled if even temporarily with mechanical controls. The tough ones in my hay fields that improved soil conditions didn't help was multiflora rose, some thistles, johnsongrass, and "broom sage".The first two I hit with Crossbow, the second, Roundup, and the third I just live with. I think a combination of improved soil, mechanical control, and herbicides shound help the poster bring in a good crop.
   / golden rod and other weeks in the field #7
Goldenrod is a natural progression species here in unworked fields. You can fertilize or lime all you want but if you don't cut it regularly it will grow. I have had good luck cutting it right before it goes to seed. Eliminates about 30% of the plants per time doing that. Earlier and there seems to be little reduction. Later of course it goes to seed.
   / golden rod and other weeks in the field #8
Burdock, I have only had luck spot spraying 3-4 times per year. Mowing won't do it. Grows in our lawn even.
   / golden rod and other weeks in the field #9
TC - he has a hay field , as do I ...mowing often is not an option..
   / golden rod and other weeks in the field #10
We had some in our field, and the gentleman that leases it for hay rights used 2-4D on it. Took care of it with one treatment. You have to put it on at the right time though. From my understanding, 2-4D is not a herbicide, but is a steroid that causes the goldenrod to grow out of control and it kills itself by growing too fast. On the plus side, it feeds the fescue to produce more hay.
slowzuki....We cooked up some burdock root a few weeks ago. Apparently it's good for you. We sauted it in butter and let it simmered until tender...not too bad really....tastes a little like plantain.
I'm new to this obviously...I had someone mowing the fields for the hay but they're no longer in business and so I'm on my own with it now. It's been a few years since the last mowing and the weeds appear to be getting out of hand..I'll see how it looks next summer and if it doesn't look any better maybe I'll try spotting it with something.
   / golden rod and other weeks in the field #12
Goldenrod is great for bees - gives them a boost for their winter honey stores. If you can mow it once a year, try to mow before it goes to seed, and you'll stay even with it. I notice you said "It's been a few years since the last mowing...", and a few more and you'll have woods growing. I guess you know that...
Jim
   / golden rod and other weeks in the field #13
24d esther
Jim
Yeah Jim..that's why I'm getting kitted out for mowing. ...seems to me though that trying to keep ahead of these weeds is gonna be a little like Elmer Fudd trying to keep ahead of that wascally wabbit. :laughing:
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
ASSET DESCRIPTIONS & CONDITION (A59904)
ASSET DESCRIPTIONS...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
