Golf Cart advice, gas or electric?
   / Golf Cart advice, gas or electric? #21
The Polaris EV uses a "Delta-Q" charger that has several charging profiles ("algorithms") built in. They come from the factory with the algorithm set at "72" which intentionally starts at a high charge rate so that Polaris can advertise quick recharging. Very tough on the batteries and often causes them to "boil". They can easily be reset to a more gentle "overnight" charge algorithm that is much nicer to the batteries. Polaris/Delta-Q recommends that their charger be left on ALL the time, since the terminal charge is a very slight maintainer rate.
I assume that other high-end chargers are similarly adjustable.
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A53472)
John Deere 700...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
