good remote control lights?
/ good remote control lights? #1
powerstroke444e
Central IL
more orange than anything
What I have a need for is a good wireless 100'+ range wireless light that I can control from my trucks as with the new shed and driveway it would be nice to have the lights come on before I back in to the driveway. I tried a chamberland but it don't work more than 10' away. I don't know if there are amplifiers for them or am I looking for something that don't exist? I don't like motion lights as the my dogs seem to set them off all the time. Any ideas? I know that the one for my wireless remote starter worked up to 300'+ so it is possible. Price is not as important as long as it works. I have been all over ebay and the the net looking.
Thanks for the help.
/ good remote control lights? #2
Are these lights along the driveway and the shed, or just on the shed?
Aaron Z
The lights mounted on the shed & house 600watts total 4 150w lights and they light up the parking lot between them and they are on one switch. The idea is to keep the help and me from backing over something when they bring the equipment back, as its a little tight but with the lights on or in the day light it is very easy to back in with out hitting something, I figure if I spend $500 on this its cheaper than fixing one truck again. I would say that once a week for 10 mins is all that the lights get used. I am to lazy to park in the road then walk to the shed and turn them on when needed. I would most likely need 3 controlers so that everyone would have one when needed.
/ good remote control lights? #4
I'm sure there must be a remote, but I don't know where to get one. My thought would be to run a three way switch to the end of the driveway. This would also eliminate the need for 3 controllers.
/ good remote control lights? #5
Preferred technologies Cartell or the one from Mier products. Will only sense a vehicle, nothing else, then turn on the lights or a beeper.
/ good remote control lights? #6
Look at adding a x10 system to your lights, or anything else you want to control remotely.
/ good remote control lights? #7
If you were to go with an X10 system I would suggest:
Item Price Qty Total
SlimFire Keychain Remote $19.99 3 $59.97
Transceiver Module (TM751) $12.99 2 $25.98
3-Way Wall Switch Module (WS4777) $15.99 1 $15.99
Grand Total $101.94
Uses:
One remote for each vehicle
3way switch would replace your existing switch, if you only have a one way switch they have one that is ~$13.
I would then see if you get the range you want with that setup. If you dont get enough range, I would see what extra range a Transceiver module would give you and mount a transceiver in/on the corner of the house closest to the road.
If that was close long enough for the transmitter to work, I would run a buried wire out to the end of the driveway and put a transceiver into that. Then I would put the other end of the run on the same circuit as the light switch. That should give you the range to get out to the end of the driveway.
Aaron Z
/ good remote control lights? #8
I put in a driveway sensor for that reason. It sends a beep to the house to let you know someone is coming up your driveway and also turns the lights on for 15-20 minutes. Didn't take the dogs long to figure out what the tone meant. Just make sure it is far enough off the road so when people turn around in your drive way they don't set the thing off.
/ good remote control lights? #9
Exactly what I suggested. X-10 is sometimes hit or miss, also prone to "phantom" operation and if there's multiple phase electric, forget it.
The driveway alert (not motion based) is the easiest, no trenching, and depending on your existing wiring, one of the better solutions without having to add a ton of stuff.
/ good remote control lights? #10
If you don't mind my asking, what brand driveway sensor and where did you get it? Does the sensor use batteries or does it have to be hard wired?
/ good remote control lights? #11
powerstroke444e,
How about cell phone control, from wherever.
A Remote Power Switch activated with a phone call
Years ago, someone had a phone activated unit to do various things like turn on sump pump, turn on AC, turn on lights, etc. You simply dialed your house number, and the unit answered, and you pressed certain numbers to activate certain things. You could also listen to conversation or dogs barking , etc. I am sure there is a similar system out there.
http://www.smarthome.com/300601/Telephone-Controller/p.aspx
http://www.iec.net/adp0201.html
http://www.remotepowerswitch.com/rps.htm
http://www.smarthome.com/30416A/Thermostat-Telephone-Controller-ACC0433/p.aspx
Read . TO TURN ON A LIGHT
/ good remote control lights? #12
powerstroke444e
I use these for my generator (2 channel) and for some lights (4 channel) at my cabin
Auto Roll 4 Channel RF Remote Control
4 channel
if you are electrically they work great we have 3 remotes for each one wives mine and a spare we pull up the lane and hit the button and generator starts right up..
tom
Well I started reading about he 10x stuff and still trying to get my head around it but it looks like it may work. If I put the controller on my porch which is about 60' the 10 x system will got threw the wires and to the switch in the shed ? 190' way to turn the lights on? If I am on the right path please let me know. As a cell phone system won't work as I don't have internet @ my home.
/ good remote control lights? #14
I might suggest a garage door opener, that not only opens the door but turns on a light (could add more lights for the drive to be lit up as well).
For a driveway alarm, I use the Radio Shack Reporter wireless alert system. Units are about $80 and the batteries last a long time. Receiver in the house will ring the doorbells. Also can wire it through a motion detector circuit to get it to turn on a house light for the length of time a motion detector can be set.
/ good remote control lights? #15
You only use the aux plug for the lights. You dial the number, and enter the code, and the lights come on.
/ good remote control lights? #16
I just wired my outdoor lights to an old garage door opener and it works at least 2-300ft.from the garage.
/ good remote control lights? #17
There's a few manufacturers out there, both wired and wireless. I've only installed wired, but I've had to look into the wireless ones as well. There's Cartel, Mier, Dakota alert, and a few others, depends on budget and what you want it to look like/not look like when done.
Keep in mind, this is part of my daily trade.
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
