Got a little carried away...
   / Got a little carried away... #1
IH782
NEPA
Kubota 2650 Kubota B7800, Kubota L3901, Mahindra 2538, Mahindra 2555
We took down a 2nd growth Red Oak and, me being me, wanted the longest lengths possible. Well, as I was lowering the biggest log (second from the back) in the picture it got stuck in the grapple and rolled forward about a foot. I heard a loud pop, it came from where the loader arms mount to the posts. Other than the sound I cant find anything wrong, loader is still level. Anyone else ever had this happen? From the log weight chart it weights about 5,200 lbs. Maybe I'm just being paranoid.
   / Got a little carried away... #2
I personally would drop the loader off for a full inspection of the main uprights, especially the 'saddles' the pins rest on. Look for tiny stress cracks and fractures. Look down the main beams at all the welds to the subframe. Inspect around all of the bolts mounting the subframe to the tractor (good time to also put a 4' pipe on a breaker bar and put some torque on all the loader mounting bolts).
It is also entirely possible the noise sourced from farther up on the loader and with all of the weight out front, the noise simply sounded farther back at the main pivot/joint.
   / Got a little carried away... #3
Could be anything.....my SWAG is the loader frame and engine mount bolts are known to need retorqued at 50 hours. I've seen several posts reminding folks to check those after finding one or more lose. That could/would cause a pop sound.
PUT YOUR ROPS BACK ON ;^)
   / Got a little carried away... #4
5200#! Dang, that's a big one. I would have guessed more like 2k. HOw long was it? How many horses is that tractor and what is the loader rated for?
   / Got a little carried away... #5
Methinks that don't weight 5200 lbs considering your tractor managed to get it off the ground.
For example a 7' long log 2' in diameter weighs 1400lbs at 64 lbs per cubic foot which is what red oak is supposed to be wet.
   / Got a little carried away... #6
I would also start checking everything, including bolts. Also check the front axle, and every mounting point.
I also doubt that is 5200lbs - that loader is strong but not that strong - have to figure in the weight of the grapple as well as it being out from the pivot point. Which is a good thing as it should not have hurt anything. Sometime you do get a weird noise or pop on Eqpt and never really know what causes it.
Loader is rated at 3400 lbs. for some reason this machine is a Pit Bull when it comes to lifting. That was as high as I could lift it in that picture.
Log was 11'
40" at big end 36" at small so averaged at 38"
Sherrill Tree log weight chart says around 475 lbs, per foot, for Red Oak at that diameter, multiplied by the length, comes to 5225 lbs. could it be lighter, absolutely.
Tractor is a 2555, 55hp Mahindra, rears filled.
This was a Live Oak around 3800 lbs.
Thanks for the tip. I try to keep the ROPS on as much as possible.
   / Got a little carried away... #9
If you are able to lift almost 2000lbs over your rating please check the hydro pressure and the relief. Something is WAY off and that will cause serious damage (and a safety hazard). Something is going to give with that much weight over rated capacity.
Cool photo however!!
I have been meaning to, it lifts a little to well. Thanks
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2022 Behnke Trailer (A55973)
2022 Behnke...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE 32"...
light tower (A56857)
