Got bit by overhead diesel tank contamination.
   / Got bit by overhead diesel tank contamination. #11
It seems like the stuff to worry about is anything on or in the filler nozzle, or dust and debris that gets blown up in a gust of wind while filling.
Filters on the tank can't help with those, And stuff does happen like that.
Just got to do what you can and roll with the punches
   / Got bit by overhead diesel tank contamination. #12
   / Got bit by overhead diesel tank contamination. #13
   / Got bit by overhead diesel tank contamination. #14
I regularly drain off the junk in the bottom of my 500 gallon bulk tank and I add Powerservice biocide and Diesel Kleen as well.
AS it should be.
To the OP: Does your diesel tank have a drain at the opposite end? Your tank should be sloped a bit away from the fuel hose end. A valve needs to be installed opposite the fuel delivery end and contents drained off occasionally. Water is going to accumulate in an outside tank so a drain is needed to remove the sediment or you will have problems even with a filter.
   / Got bit by overhead diesel tank contamination. #15
AS it should be.
Good advise on the tank slope
Very few overhead tanks (of size anyway) left in my area. Double containment is mandatory.
AS it should be.
Going to slope it like it used to be.Set it on cement pad now verses boards in the dirt area.Also starting to enclose both tanks to get them out of the weather.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
Electric Forklift Pallet (A50322)
Electric Forklift...
