Got my Tractor, hydrolic line busted after 4 hours use
   / Got my Tractor, hydrolic line busted after 4 hours use
He also provided me with the following numbers as proof of the year.
C5NN7006, he said the 7 and the 6 on the end signifiys the year of the tractor.
So i did do some research and I did guestioning before purchase.
But when he provieded me with these numbers with the 7 and 6, and said that proves its a 1976. I was satisied at that point that he was telling the truth.
PS I can not find these numbers on the tractor. The engine number is C5NN6015B I think the C is 8speed and the B stands for Basldon England, but I cant fiugre out what the rest mean useing my identifying chart I found.
   / Got my Tractor, hydrolic line busted after 4 hours use #72
the model id code identifies the tractor parts, and due to the first number or letter of the code being either a letter E or a 5 tells you if the machine is a 4-68 or newer.
for instance.. 65 to 3-68 the first digit of the id code on a 5000 is the number '5'
on a 4-68+ model, the first digit of the odel id code on a 5000 is the letter 'D'
that alone should have told the seller that he was selling an early unit, not a later one.
then you can check the date code for more definitave date, and then check the sn as it will coinside with the other 2 numbers dates.
plain and simple. the seller doesn't know how to date a ford tractor of that era and goofed up.
soundguy
   / Got my Tractor, hydrolic line busted after 4 hours use #73
you guys need to quit looking at raised casting numbers.
the serial number first digit is what tells you where it was made.
the c5nn6015b is a RAISED casting number and so is the c5nn7006
ONLY, ONLY ONLY refer to the stamped numbers when dating these machines.
your sn is C159450.. thus it's a us machine.. had it had a B prefix it would be basildon.. etc.
again.. sn, model id# and date code are all HAND STAMPED..
that's the only numbers you need to pay attention to. so much wild speculation about a black and white subject...
it's like the blind leading the blind in here.... :(
soundguy
Thank you Sound Guy.
Yes Sound Guy, You know, ad I know now, that the casting numbers are not how you accurately identify the tractor. I offered that only as what the dealer offered me as proof of identification, after I questioned whether he was really offering a 1976 Tractor. Obviously, he did not and does not know how to read indentifiying numbers either.
But thanks to everyones help, I have the correct numbers to identify the tractor now. thank you all so much.
   / Got my Tractor, hydrolic line busted after 4 hours use #76
that dealer is scarry if he is making up stories about the trranny casting number and re aranging the numbers trying to say that is a date.
sad , scarry... , fraudulent....
soundguy
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
2019 Chevrolet Suburban (A53424)
2019 Chevrolet...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
UNUSED LANDHERO CHAINS, BINDERS & DBL CHAIN SLINGS (A54757)
UNUSED LANDHERO...
