Got stuck today
   / Got stuck today
From deceased epic contributor, jinman: ..when you step on that pedal, it moves a shaft attached to a shifter fork inside the differential case. The shifter fork moves a "clutch" with four fingers to mate with the differential gear case and lock both axles. If the differential lock is engaged while the tractor is moving, those fingers can be damaged or bent. All you will do by forcing the pedal or shaft is to do additional damage. If you can't see something binding on the shifter shaft externally on the linkage, there is certainly nothing inside that is going to be cured by slamming or hammering on the engagement lever or shaft. Differential lock works smoothly or it is broken/malfunctioning. What you are doing by forcing the shifter is the same as trying to force a shift lever on a standard gear transmission. You will only make the problem worse internally or break the external shaft in the process. You will have to go into the differential and fix it or just live without differential lock. I'm pretty sure the former owner must have engaged the differential lock while the tractor was moving or turning and messed up the lock clutch fingers.
https://www.tractorbynet.com/forums/parts-repairs/268827-tc33d-cant-engage-differential-lock.html
I do recall some of his posts before he passed. He is missed by us all.
Thank you for finding a few of his words of wisdom. For this post I am believing the fork must be bent. I was always in the habit of stepping on the dif lock pedal while the tires were moving.
Do you have any idea how hard it is to replace the fork?
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
