Govenor problem on Satoh Buck
   / Govenor problem on Satoh Buck #1
Steve777
Bronze Member
I am having some intermittent problems with the governor on my 83 Satoh Buck. It seems to happen after about an hours of use (eg when fully warmed up). The symptom is that when the governor would normally kick in, in response to an increase in the load, the engine stumbles and almost dies. If I hit/play with the throttle pedal the engine will keep running, although it is a bit rough, almost as though one cylinder was not firing right. But there is no sign of roughness in the engine before the speed was increased by the throttle/governor.
I had thought it might be an air leak in the fuel lines, so I tightened the clamps up (and there was one somewhat loose but not leaking fuel). However as this is an intermittent thing it is hard to say if that fixed it or not.
Any suggestions for other possible causes, or things to check?
TIA
Steve
   / Govenor problem on Satoh Buck #2
Haven't had that happen on mine yet. Are you sure your filter is OK? How about the vent in the fuel cap? Make sure you eliminate the easy stuff first is all I'm saying. My Buck has been rode pretty hard.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
MULCHER (A58214)
MULCHER (A58214)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2018 FREIGHTLINER...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2017 Kustom Signals Towable Solar Radar Speed Limit Trailer (A59228)
2017 Kustom...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
