I have a 1020 Hydr 2wd and it seems as though it does not have a governor. I really notice this if I have a pto generator hooked up. Set it at rpm and as more load is required it does not make any attempt to recover or compensate for the added load. Same thing while mowing, if run into heavy pulling I either have to slow down or add more throttle. It has done this since new. Also have two other 1020s in the family and they are same.
Not a big issue but was just wondering. I don't believe the service manual shows any adjustments for the pump but I may be wrong. Shows it to be a Toyosha ( HINOMOTO ) engine with a Diesel kiki injector pump.
