GPM vs tubing size
   / GPM vs tubing size #1
woolyAcres
Platinum Member
Western PA
Antonio Carraro TTR 4400
I'm planning a modest FEL overhaul and I'm interested to know how pipe sizes fit into this. I'll be replacing my old, worn-out, and troublesome loader valve with a new joystick control. Most of the hoses still hold pressure, but are pretty ratty and some may not be the correct length given the different mounting requirements of the new valve. So I'm looking at new flex hoses. Currently the flexible and rigid lines are 1/4". I don't have any interest in changing out the rigid lines (running along the loader arms to within 12" of the cylinder connections). Does it make any sense to upsize the flex hoses that go between the valve and the fixed lines, or should I just use 1/4" all the way?
My inclination is to put 3/8" hoses from the valve to the rigid lines. Would 1/4", or 1/2" for that matter, really change performance at all?
Thanks
   / GPM vs tubing size #2
No you would not notice much if any difference in operation of the FEL with 3/8" or 1/2" lines being fed by 1/4" tube
It's actually the other way around - 3/8" or 1/2" lines feeding into 1/4". Basically it would get smaller as it gets closer to the cylinder. But I suspect in this case, the order doesn't really matter. There won't be much benefit.
2003 INTERNATIONAL 9200I TANDEM AXLE DAY CAB (A56129)
2003 INTERNATIONAL...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
2018 FORD F-350 (A55745)
2018 FORD F-350...
2022 31 MINI SKID GRAPPLE BUCKET (A55745)
2022 31 MINI SKID...
2004 INTERNATIONAL 4300 BOX TRUCK (A56129)
2004 INTERNATIONAL...
3650 (A47477)
3650 (A47477)
