locknut
Platinum Member
- Joined
- Jul 31, 2006
- Messages
- 576
- Tractor
- Kubota
Thanks Locknut...you are correct...the 7xx Deere series w/AWD does price out $3-4k higher. It does seem like I have read a number of very disappointed GR owners stories. Also, my Kubota dealer essentially does not sell them...steers customers to the BX series. AWD and a Kubota diesel for under $10K is pretty competitive. Glad to hear from a "happy GR customer". May have to take another look...Thanks...TMR
P.S. Do you mow much uneven or rough ground? What about grass/weeds that may be quite tall...say 12". I borrowed a used BX from the dealer and it handled the tall material quite easily...I attribute part of that to the torque of the diesel? BTW...do you have gas or diesel? Thanks...TMR
All the problems were with the early models.My dealer did all the upgrades on mine(warranty);new case w/axle bearing setup instead of bushings,improved pto engagement parts,larger cc charge pump,etc.It's stronger today than when new.Helps having a good dealer that's on the ball.A lot of early owners were not so fortunate.I mow 2 acres of very rough,hilly property up to 30deg+ and only mow every two weeks,so in the spring it gets a workout.And,I do a lot more with it than just mowing chores.I put the FEL on yesterday and spread some crushed stone on the drive.That's the most fun attachment I've built for it.Check all my started threads here.GR2000 gas.
Greg Barker's Library | Photobucket
