Grader Blade Help
   / Grader Blade Help #11
Everything Attachments 5' Value Scrape Blade for Compact Tractors with 25-50 HP
That back blade has nice features. Tilt is almost a must. For ditch work it's a necessity. Easy offset is sweet to have. My neighbor has a 7' slider/tilt blade I barrow. Uses 2 nuts to lock everything in place. I used it to clean out 500' of diversion ditch down my yard. It had 10 years of fill and erosion. The infinite adjustment the slider has, allowed me to get just right amount of tilt and offset. This let my tires ride the flatest track for best results. Or tuck the blade just behind my tire to gradually increase depth of ditch. Pin adjustment looks quick and easy but with only 0°, 15° and 30° tilt settings it's going to take alot of turn buckle to get the right amount of tilt. Be nice if it offered tilt in 5° increments. A 7' blade was combersum on my GC2600 but usable. Maybe consider a 6' blade.
Setting the slider model is quick. Loosen two nuts with socket. Slide blade with short chain. Set tilt. Tighten nuts. No turn buckle adjustments needed.
I used a few blades and unless your top link is at a perfect length every time you change the pitch of your blade the tilt angle will need to be adjusted to keep blade level. I had to shorten my top link for that extra ground cleance.
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
John Deere 5075E (A53317)
John Deere 5075E...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
