Grading using a drag behind attachment for a backhoe or truck
   / Grading using a drag behind attachment for a backhoe or truck #1
Seananamous
Hill Country, Texas
New Holland
I've seen some intuitive ways of making their own boxblade and drag behind chain etc.
What do you think is the best situation for 1/2 mile of mountain top with very hard rocks?
I'm looking at some of these boxblades thinking it wouldnt stand up to what is on the top of my hill, and it's not totally flat with lots of bend.
What can you recommend?
I have a backhoe and just grade it using the front loader for now and manually with a rake.
Sorry it wasnt. Just added it now.
   / Grading using a drag behind attachment for a backhoe or truck #3
So what kind of issues do you have with drainage, runoff velocity, etc.? Center crown, water bars, etc.? Any gravel on it? Are you just looking to smooth washboards and fill potholes, or are you looking to maintain contour?
   / Grading using a drag behind attachment for a backhoe or truck #4
Here is what I made for my 1/2 mile road. No big rocks though.
No issues with drainage. The only issues I'm having is that its getting wavy as I'm using the front loader. I'd say theres some large rocks that cant be removed from the path and I've done my best to cover over it with some base material - 1-1/2 rock with dust. That's what I've mostly been using for the path.
Whats shown in this video just looks like dirt and no gravel. Would this work with 1-1/2" gravel?
   / Grading using a drag behind attachment for a backhoe or truck #6
I now have more gravel and it works great. I do have to work it when it is moist and not hard and dry. It gets rid of the whoops and washboards great - and really makes things level and smooth. The tail wheel keeps one end lifted to maintain the crown. Weight is your friend. I've seen some versions that have a cradle for a barrel that you can fill with water for weight.
Another option that might work for you would be a landscape rake you could pull like a trailer.
If it works on gravel then I'm totally interested in seeing how it's made!
The landscape rake also sounds like a good idea. Might just make my own with some rebar. I saw someone else do something similar.
   / Grading using a drag behind attachment for a backhoe or truck #8
I have limited stuff right now... A 4ft piece of RR track I use as drag to knock off high crown in road, and a 8 foot section of chain link fence folded over a "T" stake and chain to tractor and large rocks inside fold for weight to even things out... Sort of a screen drag harrow....
Dale
Do you have an image of it in action?
   / Grading using a drag behind attachment for a backhoe or truck #10
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2005 Ford F-150 Crew Cab Pickup Truck (A55852)
2005 Ford F-150...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2011 CATERPILLAR 535C SKIDDER (A52707)
2011 CATERPILLAR...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
