Fallon
Super Member
The main hydraulic pump runs steering & external hydraulics (loader, 3pt, any extra hydraulic valves, etc.). Pretty much all modern machines have a priority valve that forces a percentage of that flow to run steering. So there is no using up that flow. The pump is designed to not have enough capacity to stall the tractor.Specs say the main pump is 9.1 gpm. But I am unfamiliar with hydraulics at this level. If I suck out 7 gpm for a broom, does that leave enough flow to run the main tractor systems? Wouldn't make much sense to run the broom but be unable to drive the tractor, for instance. But this is my ignorance on this topic. And not even sure how I would tap into that.
The first valves in the flow of hydraulic fluid can divert that fluid to do work, starving everything downstream. So if you move your loader, the 3pt stops working. But the 3pt will be fine & lift as soon as you stop messing with the loader. This is relevant to me as my hydraulic post hole digger on my loader stops spinning when I lift or drop my loader. Annoying, but not problematic. You would likely see similar behavior with the broom stalling every time you changed angle hydraulically. No big deal, just slow down & know it's going to happen.
If you have a HST machine, the HST has it's own dedicated pump & motor combo in the transmission that deals with moving the machine. A GST (most any power reversers or PowerShift type machines really) has a dedicated pump in the transmission to run the clutches & other parts that make a GST work automagically. A manual shift doesnt have or need any pumps in the trsnsmission.
