Grande L30 configuration questions
   / Grande L30 configuration questions #21
I've had the Woods 7500 on a Kubota 2900 and same problem-low ground clearance. I have also used a Woods 9000 on an older 3400-better. I now have a 3830 with the BH90. Extremely easy to attach and take off as the subframe is permanently mounted on the tractor. About 2 minutes to take off and 3 minutes to put on (watch out that you don't pinch the hyd. hoses when putting the backhoe on).
Ag tires are the best traction if you're not on asphalt or concrete and will last a long time. If you are on concrete or asphalt, get the industrials. I have a tractor business, but have use both. The ag tires just don't hold up on man-made surfaces.
Good luck.
   / Grande L30 configuration questions #22
</font><font color="blue" class="small">( If you are on concrete or asphalt, get the industrials. I have a tractor business, but have use both. The ag tires just don't hold up on man-made surfaces. )</font>
I have to respectfully disagree with that statement.
If you drive your unit on man made surfaces, i.e.: asphalt, concrete, brick and leave the unit in FWA, then the tire wear is pronounced, but in 2wd, the R1's will last nearly as long as the R4's. FWA isn't advisable in no slip situatuions anyway.
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2018 Peterbilt 348 T/A Pac-Mac Forestry Grapple Truck (A48081)
2018 Peterbilt 348...
2008 Ford Escape XLT SUV (A48082)
2008 Ford Escape...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
