grapple bucket
/ grapple bucket #1
plumbstraight
Washington state and Ak
5300 John deere,53 harry ferguson, ck20 kioti, 135 ferguson, 350jd dozer, k40 kubota excavator
Several years ago I spotted some grapple buckets in a scrap yard. I was doing some underground and road repair and thought about picking up one as I was there and they kept calling me. I did some haggling and picked the best set up for 200 bucks. They have been lying around since. Cousin asked me about doing some logging on his place. I have a winch in the loader frame and is very handy, also have one on the rear with a boom so I can use tongs to just pick up a log and go. I had a good sized pile of treelength logs to sort and though about that set of grapples. Took the bucket off, quick disconnect type and fabbed the connections on the gapple bucket. Took the hyd hoses from the front winch and plumbed into the grapple. I do have quick disconnects for the hoses and will put them on later. Right now it just get the logging done.
Wow, I should have done this long ago. Being able to pile brush out of the way to get to the logs, being able to sort the wood after limbing and bucking is just amazingly quick and easy.
/ grapple bucket #2
Grapples are great. Any pictures?
/ grapple bucket #3
I sure could have used one today. Earlier in the week we had some strong winds. The wind knocked over an old dead pine tree. It was about a 40'er. Snapped it at the base which had rotted and it fell against another tree and hung there on a 45 degree angle till today. I pushed it down with the tractor and cut it up in 5' lengths. A grapple would have come in handy to pick up the cut pieces. Instead I had to roll them into the bucket to move them.
/ grapple bucket
Will get some pics up when I get back out there on Monday. The grapple came off a skidsteer so they are built heavy.
/ grapple bucket #5
You will hardly ever use your bucket once you have a grapple. Do you have quick attach on your loader?
/ grapple bucket #6
Yes, I have a QA bucket. Already have QA forks and snow pusher box. I have been thinking of buying a hydraulic thumb with two mounting plates. One for my bucket and one for the forks then switch between them.
Kubota M4700 (A60462)
2015 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2015 REITNOUER...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
2005 Sterling Acterra Tender Truck (A63118)
2005 Sterling...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
