grapple for jd790 with 419 fel
   / grapple for jd790 with 419 fel #1
omrebel
SOUTH MS
JD 3038e
I'm looking for a lightweight grapple (48 in would be ok). All the ones in a search of threads are no longer available and I'd rather not have just a bucket addon type. The 419 FEL doesn't have much lift capacity but I don't plan to be lifting heavy loads.
Also on the 790, what is this type of attachment called? pin-on?
Thanks
   / grapple for jd790 with 419 fel #2
Pin on is the original bucket attachment method. Quick attach adapters first pin on, then you have a secondary 'quick attach' interface. There's lots of grapple mfg's out there and you could start a small riot here talking about them.. I got mine (a pin-on) from rootgrapple.com and it's the best one, according to everybody.:D
Welcome to TBN.
   / grapple for jd790 with 419 fel #3
Another thing.. 'quick attach' adapters move your load a few inches further out, decreasing your lift power, if that's a concern for you.
   / grapple for jd790 with 419 fel #4
Actually, the 419 loader is quite robust for the size and weight of the 790.
However, it weighs about about 250 lbs, so you'll want to get a grapple that replaces the bucket rather then an add-on.
Markham made them, IIRC.
   / grapple for jd790 with 419 fel #5
Your 419 loader already has the JDQA (John Deere Quick Attach), both WR Long and Gator Attachments make a light duty grapple that will replace your bucket. You will also need to add hydraulic's to your machine to control it.
Here is some pictures of mine on my 410 loader, it's the LD-48 from Gator (used to be Markham till they sold)
Do a search on these terms for HOURS of reading, then come back with specific questions.
markham
gator
wr long
ld-48
grapple
diverter
3rd function
   / grapple for jd790 with 419 fel #6
I sure like the looks of that grapple.
Have come close to fabricating a single "thumb" on my forks mostly for logs and brush moving. Guess I should look closer at what Gator has to offer, but thinking I'd prefer to go under logs and brush with the forks rather than the rakers. :confused3:
   / grapple for jd790 with 419 fel #7
Thanks
I don't think you'll do better than the Gator 48light duty with JD pin on mounts. Lots written about it on TBN. Search Markham or Gator grapple (same thing).
Welcome to TBN
Thanks for the replies. I had already searched and read everything but was concerned because most weighed about 350lb+ and wasn't sure what type attachment mine was called. I've also read posts about adding a 3rd function to control the grapple (I'll probably have questions about that later). If these aren't too heavy then I can order one with the correct hookup.
   / grapple for jd790 with 419 fel #9
Your machine will handle it just fine.
   / grapple for jd790 with 419 fel #10
Kenny said it would work. That settles it. Seriously.:D
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2016 Caterpillar 349FL Hydraulic Excavator (A53421)
2016 Caterpillar...
2015 Ford F-350 4x4 Pickup Truck (A55852)
2015 Ford F-350...
2025 Spirit Carriage Electric Cart (A55758)
2025 Spirit...
