Grapple work with utility tractor or skid steer
   / Grapple work with utility tractor or skid steer #1
ih364
For several years I've been clearing brush and trees. My typical operation is to trim, cut and stack. I consolidate the stacks with a rented T-190 Bobcat and a root grapple that I own. Except for the firewood I render eveything is burned. Has anyone had the experience of a grapple setup on a utillity tractor as well as the skidsteer? I'm considering a new tractor purchase and wondering if the utility tractor would prove to be a good option for the root grapple and what would I have to do to the UT to get it setup.
   / Grapple work with utility tractor or skid steer #2
You would need a SS(skid-steer) Quick Attach on the tractor,very common only John Deere has their own,and a third function for the grapple.Some people use rear hydraulics if tractor is equipted with them.In the woods you may have to use chains,of course 4WD.
   / Grapple work with utility tractor or skid steer #3
I have used both CUTs and skid steers with grapples. The skid steer works better in nearly all cases. Vastly better front visibility to see what your doing and how the attachment is postioned, more durable FEL, quicker, much more protected in under belly and front/grill, lifts higher, digs better and easier to operate while performing multiple tasks at once.
The CUT has the advantage of rear 3 pt, rear hitch and pto for other operations, better side and rear visibility, better traction esp with r1 tires.
   / Grapple work with utility tractor or skid steer #4
Yes it will work. Works much better with a shuttle or hydro tranny. Since you own a grapple, all you would need is the Skid steer quick attach for the loader arms. Most utility tractors have rear remotes which can be used with long hoses to the front. Of course, adding a 3rd function to the loader (W.R. Long, etc) and incorporating a toggle/push button on the loader valve makes life easier.
   / Grapple work with utility tractor or skid steer #5
If you want to see one in action on a tractor...go to you tube and type in "everything attachments". I think the guy even talks about how to hook up the hydro lines. Plus he shows you some pretty good footage of it in use that might help make your mind up.
   / Grapple work with utility tractor or skid steer #6
Recently pick up anbo grapple for a Kubota 2710 with the extra hyd valve and toggle takes a little to get used to. With a landscape rake and grapple land clearing is a snap. Even knocking down large trees with a saw and cutting into 10'to 15' lengths is quick to move them out. Have to come back for stumps later, so far have been real happy with setup.
   / Grapple work with utility tractor or skid steer #7
Radman1 nailed the question. Skidsteer wins bigtime.
   / Grapple work with utility tractor or skid steer #8
I have used both the root rake and open bottom grapples on my tractors. I currently have a W.R. Long 72" open-bottom Grapple on my John Deere. Machine agility and equipment characteristics aside, the grapples are just as useful on the tractors as they are on the skidsteers. I have loaded brush, debris, and logs with with my grapples. However, I do prefer the open bottom grapple over the root rake. It just handles the material better and I can still dig roots and such with the open bottom grapple. I do have pictures posted on this site and well as videos on youtube YouTube - Using WR Long Open Bottom Grapple and YouTube - Cutting down tree and loading trailer with brush us Mitsubishi MT4201D if you would like to see them in action. Make sure that you get the size grapple that is appropriate for your tractor (or the other way around if you already have the grapple on hand). They are heavy and will give your FEL frame and cyclinders work out.
Hawk
   / Grapple work with utility tractor or skid steer #9
Hawk
Not saying that grapples are not useful on a tractor. If you have used both, a skidsteer will run circles (literally) about a tractor with one. Depends on what you want.;)
2018 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2018 Ford F-550...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
FIMCO 200 GALLON FENCE ROW / CATTLE SPRAYER (A52708)
FIMCO 200 GALLON...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2022 Chevrolet Express (A57148)
2022 Chevrolet...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
