Grass Seeders / Drills
   / Grass Seeders / Drills
I got quotes from local dealers on both the Woods STR-60 and the LandPride APS 1560... They both came back about the same ($5k), except that an extra seed box is available for the LandPride which adds another $1800.
Has anyone used both? Any preferences?
Thanks,
Jeff
   / Grass Seeders / Drills #22
I got quotes from local dealers on both the Woods STR-60 and the LandPride APS 1572... They both came back about the same ($5k), except that an extra seed box is available for the LandPride which adds another $1800.
Thanks,
Jeff
In your original post it sounded like you are only planning to plant grasses. But, if there is any chance that you will plant bigger seeds at some point, you may want to ask about how each machine handles bigger seeds. When I was looking at these two machines to plant mixed covercrop including oats, vetch, clover, austrian peas, and fava beans, Woods told me that their machine would crush the larger seeds and Landpride told me their machine could handle them all. $1800 for an extra seed box seems pretty pricey, but I didn't check that out because I buy pre-mixed seed.
Also, while it probably doesn't matter for your application it was important for mine, the actual width (as opposed to the working width) of the Landpride machine is somewhat narrower than the Woods machine.
In January I was quoted $4100 for a Woods STR48S-2 and $4200 for a Landepride APS1548-01.
For now, I'm planting grasses... But maximum versatility is a bonus, and I do plan on planting other types of seed in the future. The more that I can do with one implement, the better.
Thanks!
Jeff
   / Grass Seeders / Drills #24
Thanks,
Jeff
Hello Jeff,
As long as you are still looking you should price the Brillion seeders too
as they offer two models for what you wish to do.
   / Grass Seeders / Drills #25
Jeff,
I have broadcasted Fescue using the method in your first post but also rolled the seed after covering. Rolling for good seed to soil contact really helps.
I will be interested to hear the results using a no till seeder if you go that route, My experience is that the grass does much better with a properly tilled seedbed. I have places that the no till method could be used for so I will be interested to see how this works out.
   / Grass Seeders / Drills #26
You could save by buying an older used seeder in good shape. We found an old Deere grain drill with the extra small seed box. It works fine. But keep your eyes out for a heavy pasture seeder. These will reseed pasture in one pass. The discs cut a slice in the sod, drop the seed and press it in.
   / Grass Seeders / Drills #27
Flusher, Your homemade drop seeder is a beauty!
   / Grass Seeders / Drills #28
Same here. I bought a 2-row JD 71 Flexi-planter ($1K plus shipping) to put in Austrian winter peas and fava beans this year. My old restored Minneapolis Moline P3-6 grain drill wouldn't work (crushed these seeds).
   / Grass Seeders / Drills #29
Thanks--it was a fun project.
One of these days I'd like to get my hands on a Brillion grass seeder to see how it compares to that DIY seeder of mine.
   / Grass Seeders / Drills #30
My 6' Great Plains 3P600 drill is an excellent seeder for all size seeds, with minimum ground prep. We're in the process of changing the width of our vine aisles to where the drill would no longer fit. So, after researching a number of different types and brands, I ended up buying a Kasco KVS-483 vineyard model. Its a curtain seeder with disks ahead of the seed hopper and cultipacker following it. My dealer got it for $4600, delivered. Since I use the seeder for cover cropping, I decided to trade off the precision and economy that a drill provides, for curtain coverage.
Extra Heavy Duty Powder Coated Hay Feeder (A49251)
Extra Heavy Duty...
Bush Hog 1815R1 15ft. Batwing Mower (A49339)
Bush Hog 1815R1...
2011 Ford F-350 Knapheide Enclosed Service Truck (A46683)
2011 Ford F-350...
1998 FONTAINE TRAILER CO. 48X96 FLATBED (A48992)
1998 FONTAINE...
2025 Bale Spear Skid Steer Attachment (A49346)
2025 Bale Spear...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A46684)
2007 Ford F-150...
