KennedyDiesel
Veteran Member
If the gravel is not yet frozen, you need to use skid shoes OR flip your rear blade around backwards so it does not cut in. This greatly lessens the effectiveness of the blade. I also flip the blade around for light finish grading the gravel.
I have a 54" front blade for my 455 that works well so long as the shoes are set properly.
For light finish work, and weed ripping in the gravel I still like my home built floating drag behind my 455 with a couple of cement blocks for weight. The front arms are like this: \ / only less angle, and the rear about 3' behind and is straight. I made this about 10 years ago. I also plan to try a box blade
