kermitismydaddy
For me, a rear blade is just about the most important implement for road work. I can do without the others if I have a rear blade that has angle, tilt, and offset adjustments and if it can be adjusted hydraulically, all the better. With a blade that has offset to either side and sideways tilt and angle, you can even cut ditches for drainage along the sides of a gravel road or for a fire-line almost like a plow. A box blade is best for leveling were-as a rear blade will easily allow you to put a crown on the road and pull gravel back from the edges.
That sounds like sage advice. TY!
